  Ecotec A/C compressor clutch life used with CCOT Fiero system?
Ecotec A/C compressor clutch life used with CCOT Fiero system? by fast40driver
Started on: 02-08-2015 11:18 PM
Replies: 2 (188 views)
Last post by: fast40driver on 02-11-2015 12:27 AM
fast40driver
Report this Post02-08-2015 11:18 PM Click Here to See the Profile for fast40driverSend a Private Message to fast40driverEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pretty well as the title says - any of you smart A/C types know if the compressor clutch life will be significantly affected if I use it on the Fiero CCOT system as is?. Or am I just worrying too much? Easier just to sway the compressor if it fails?
I know I need to add the limit switches that are not present in the Ecotec compressor.
Mike
Report this Post02-09-2015 12:30 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ecotec is V5 compressor?
Then Loose (bypass) clutch switch. V5 doesn't need this. See 87-88 Fiero L4 A/C wiring diagram... 87 L4 came w/ V5.
All system should have High and Low cutout switches. USEPA/USDOT now requires cars to have high cutout to prevent over pressure the system and cause refrigerate escaping from blowout. If you refit the old system and didn't have one then add it.
Many have 2 high switches... 1 normal high pressure, 1 higher pressure as a backup.
fast40driver
Report this Post02-11-2015 12:27 AM Click Here to See the Profile for fast40driverSend a Private Message to fast40driverEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the response. Didn't think Ecotec was a variable displacement compressor - uses a thermostatic expansion valve.
Mike
