  Relocating Antenna to under the Fender
Relocating Antenna to under the Fender by Leviathan
Started on: 01-10-2015 10:59 AM
Replies: 30 (1464 views)
Last post by: Dennis LaGrua on 08-07-2024 08:48 PM
Leviathan
Report this Post01-10-2015 10:59 AM Click Here to See the Profile for LeviathanSend a Private Message to LeviathanEdit/Delete MessageReply w/QuoteDirect Link to This Post
* Reserved for future use
Leviathan
Report this Post01-10-2015 11:11 AM Click Here to See the Profile for LeviathanSend a Private Message to LeviathanEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was working on my 88 GT the other day and the ugliness of the antenna started getting on my nerves. Its time that it moves itself underneath the fender. Im almost done with the relocation, but I need some help finding out some information about the stock antenna system.
To be able to get to the frame underneath the quarter panel without taking the entire quarter panel off, you have to remove the antenna from the Antenna Base that mounts onto the frame. I removed the original antenna with a wrench, but sheared the bolt on the Antenna Base. This sounds like its a very common problem. I bought a new antenna that uses an M6-1.0mm thread - Is this the same as the original antenna?
On the Fiero Store, i could buy a new antenna base for $30, make a bracket to hold the antenna base sideways and mount my new antenna on the antenna base. I dont like this idea because the only location with enough space is so low on the car, you would most likely have remove the quarter panel and wheel well cover. I felt like i could come up with a better design with a better location that requires less work for cheaper.
http://www.fierostore.com/P...Detail.aspx?s=61602U
https://www.fiero.nl/forum/A...040710-2-048858.html
After deciding to not use the stock antenna base, i ran into the problem of connecting the existing coax antenna cable to my new antenna mount. I went to my local car audio store to see if they had any connectors to would fit the coax cable, but i wasnt able to find anything that would work. It seems that this magical unicorn connection between the coax antenna cable and the antenna base does not use standard connectors. Finally, I was able to make my own connector by cutting up two standard coax cable connectors that can be found at a car audio store and combining them. Does anyone know if there is any premade connectors that fits the coax cable that plugs into the antenna base?
Also, if a man was to remove the antenna, but leave the antenna base installed on the car, does the bolt on the antenna base stick out of the body work? Since that bolt sheared off, im not able to tell.
Relocating this antenna has been such an ordeal with breaking parts and finding the right connectors, im wondering if there is a kit that already exists or if a kit needs to be made. Ill post some pictures showing where i plan on relocating the antenna and the special connector that i made. I hear that an antenna mounted on both sides of the car gives the best reception. I may do this in the future as well, which would require an additional custom wiring harness.
Question 1: What is the thread of the bolt that protrudes out of the antenna block mounted on the frame that the antenna screws on to?
Question 2: Is there a premade connector that fits the coax cable that plugs into the antenna base?
Question 3: Does the bolt on the antenna base stick above the body work when the stock antenna is removed?
tshark
Total ratings: 68
Report this Post01-10-2015 11:16 AM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Report this Post01-10-2015 11:20 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
At a show a few years ago I spoke with a Fiero owner who used the defroster trace on the rear window as his radio antenna.....he said it worked perfectly.
David Hambleton
Report this Post01-10-2015 11:51 AM Click Here to See the Profile for David HambletonSend a Private Message to David HambletonEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's an interesting idea. Does the ground side of the coaxial antenna cable need to be grounded near the window?
Leviathan
Report this Post01-10-2015 11:54 AM Click Here to See the Profile for LeviathanSend a Private Message to LeviathanEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Coax Cable that plugs into antenna base
CLICK FOR FULL SIZE
Antenna Base
CLICK FOR FULL SIZE
CLICK FOR FULL SIZE
(Notice how far recessed the male pin is in the antenna base)
Custom connector that plugs into the Coax Cable
CLICK FOR FULL SIZE
CLICK FOR FULL SIZE
[This message has been edited by Leviathan (edited 01-13-2015).]
Leviathan
Report this Post01-10-2015 12:00 PM Click Here to See the Profile for LeviathanSend a Private Message to LeviathanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Leviathan
Member since May 2014
Originally posted by tshark:
This may be of help. There is also a hidden antenna on ebay. I used one in a previous Fiero.
I don't have answers to your questions.
Tshark, thanks for the link! I saw that as i was doing some research. Thats a really slick way of hiding the antenna. Unfortunately, im too lazy to do that work... Thats an awesome job they did.
Ill try to figure out why the photos didnt post correctly... If you click on the error messages, it will take you to the photos in PhotoBucket. Also, i should have this project finished by tomorrow and i will show my mounting bracket and antenna placement.
Total ratings: 466
Report this Post01-10-2015 02:49 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
The preferred method of posting images here is PIP... and the images will never disappear from the posts/threads.
I didn't hide my antenna, but I started out with the same problem as you (as discussed in this thread - Antenna replacement). Might be something in there that could be helpful to you.
Originally posted by Alibi:
You don't have to remove the cable (from the car), it just plugs into the base. It is stubborn so spray it with some penetrant first and then twist it off, don't yank or else you might pull the end apart.
Originally posted by Patrick:
I picked up a Formula last year that had the stud broken off the antenna base. With everything else I've been doing with this car, fixing this issue was low on my list of priorities... so I've suffered for the last year with very limited radio reception (no antenna).
I finally decided to fix this, and I was very happy to read the above post and realize that the coax cable did NOT need to be removed from inside the car.
Sure enough, the coax cable just sort of twisted/pulled off the base. Did the opposite to attach it to a good base from one of my parts cars. I've got a zillion radio stations to listen to now!
I love this forum. Special thanks to Alibi for the info quoted above.
Leviathan
Report this Post01-10-2015 04:51 PM Click Here to See the Profile for LeviathanSend a Private Message to LeviathanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Patrick, ill try to correct my images using PIP sometime in the next day.
Thankfully i tried to pull the coax cable out of the antenna base before i decided just to cut the coax cable at the antenna base. You are right, you dont have to pull the entire cable through the frame right in front of the door.
I just need to pick up a few parts to finish the relocation. Im very pleased that all you really need to do is loosen the quarter panel enough to pull it away from the frame to be able to have enough access to mount the antenna. Ive seen way to many forums were they have taken the entire quarter panel and wheel well cover off.
I reserved the first post so that i can go back and post a tutorial along with a wiring diagram, etc.
Total ratings: 461
Report this Post01-10-2015 10:10 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't know if this was mentioned elsewhere, but you should put a piece of plastic tubing over the antenna. If the metal mast touches the spaceframe it will likely kill the signal.
Also, having the antenna in close proximity to the spaceframe will tend to shadow the signal, and make the antenna very directional. (Sounds like you already know that.)
Leviathan
Report this Post01-11-2015 10:20 AM Click Here to See the Profile for LeviathanSend a Private Message to LeviathanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, Great point. I cant remember where i read it, but somebody put an antenna on both sides of the car and said that that gave them the best reception (better than the stock antenna location). I have to assume that he put an antenna on both sides because of what you mentioned. Im sure the spaceframe blocks a lot of signals from the other side of the car.
During my commute to work, i go in and out of range of a few radio stations. I know where the signal normally ends. When i get the car back to together, im curious to see how much the antenna relocation hurts my reception.
Report this Post01-11-2015 11:16 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fender is low plus frame is ground plane and hides the antenna from getting good signal, especially at medium to long distances.
I just put a wire along the edge of windshield and connected to antenna base.
Hides the antenna w/o killing signal. Did that because kids break off antennas.
Two antennas can cause signal problems and often not a simple as splicing two antennas to a wire.
You should read real antenna data, not BS posted on many forums.
Orig88GT-NC
Report this Post01-11-2015 05:48 PM Click Here to See the Profile for Orig88GT-NCSend a Private Message to Orig88GT-NCEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think ( theogre ) is onto something with just attaching a wire to the Antenna Base stud .
It would give you more flexibility in your mounting, and you might be able to bring the wire up the A-Pillar by carefully tucking it between the drip rail and chassis as an option.
The length of the wire is important for good radio reception,( advised to me by people who know alot more about radios than me ) so I would start with a wire that is 32" long ( same as the original antenna mast)
and go from there.
In your original question you asked about ......
* the antennae base stud size?....measured this mourning, its metric ( M6 x 1.0 ) ~ 8mm in length.
* and does it come through the fender? .... No, it sits below by about (3/16" to 1/4")
Report this Post01-12-2015 01:16 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
and go from there.
OE radio uses AM and FM and means different bands. (AM 530-1610KHz, FM 87-108MHz.)
will get different tuning on a band but really is not a big problem for receiving. A poor tune of antenna is more of a problem in rural areas because that will kill channels.
Is a big issues using any 2-way radio. Miss-match eats power in transmission and can ever kill the radio's output transistors.
Perfect match to a channel can vary a lot... long story, google: 1/4 wave antenna length
Good calculator is http://www.csgnetwork.com/freqwavelengthcalc.html
Examples:
1/4 wave antenna for X channel = Y
108MHz = 27.33 Inches (high FM)
100MHz = 29.52 Inches (middle FM)
88MHZ = 33.55 Inches (low FM)
1000KHz = 2952 Inches/246 Feet (middle AM)
Just for fun...
27MHZ = 108 Inches/9 feet for CB radio band. Is why "whip" antennas are 9 feet. All Shorter uses load coils.
WiFi 2.4GHZ band = 1.23 Inches for 1/4 wave, 4.95 full wave
Your 32 inches means is tuned for FM band but a few inches off won't matter much. AM can use same antenna
especially because you aren't transmitting.
Bigger issue is the antenna hidden in the fender. Car's body is the ground plane for all antennas attach to it. You don't want your antenna buried in the car's metal to get a good signal. (google: antenna ground plane)
Have antenna close to A pillar isn't the best but likely better then under fender. I get most channels using a wire under glass trim even driving in rural areas.
Total ratings: 461
Report this Post01-12-2015 08:23 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ogre's idea about using a wire inside the windshield trim sounds like a good idea.
In reality, you could probably run a wire underneath any body panel and receive a decent signal, provided that you weren't using metallic paint. The metal flakes in the paint might tend to block the signal.
Ideally, you would want to keep the wire as far as possible from the metal structure of the car, as he mentioned.
My dad used to experiment with antenna design for some two-way equipment that we had. He got the best results from some of the damnedest things.
Play around. Figure out what works.
I realized, when I bought my G6, that the radio antenna looks like part of the rear window defroster grid, except that it's at the top of the window, and separated from the real defroster by a couple of inches.
In the 60s, GM used wires embedded in the windshield glass for radio antennas. They sort of worked. I'll bet they would have worked better for FM, had it been in common usage at the time.
[This message has been edited by Raydar (edited 01-12-2015).]
Total ratings: 466
Report this Post01-12-2015 08:47 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I remember that as well, but I think it was bit later... maybe the 70's. Anyway, it was back when we were young and fearless.
Report this Post01-12-2015 09:13 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Early 70s... Family had a GM car w/ this. Other markers still use this plan.
Two fine wires you could see.
They work good in most places.
is hard to see because tint... start at bottom then bends 90° about 2-3 inches at top
CLICK FOR FULL SIZE
source: ebay listing
[This message has been edited by theogre (edited 01-12-2015).]
Leviathan
Report this Post01-13-2015 09:19 PM Click Here to See the Profile for LeviathanSend a Private Message to LeviathanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Awesome information Ogre! Great job educating about wavelength.
Real Fast, i fixed my pictures in the first few posts, thanks Patrick
I wouldnt be happy with myself until i found out how much signal i lost with the antenna being placed under the fender vs the stock antenna location vs a wire on the dash.
When i was in college, we used to use these extremely expensive devices called Spectrum analyzers. They are used to probe RF electronics and display the amplitude of signals at various frequencies. For example, if you make a 1Mhz sine wave generator, you will always have harmonics that appear in the signal (2 Mhz, 3 Mhz, 4Mhz etc.) The harmonics will always be less than the primary signal, but can cause problems in some circuits. Normally, spectrum analyzers cost a minimum of $2,000 - $4,000 for a decent one.
Picture of a Spectrum Analyzer:
I found an incredible device for $20 that allows me to do exactly what a spectrum analyzer does between the frequencies of 22Mhz to 1.7Ghz. It was originally designed to be a TV tuner that allowed you to watch analog TV channels on your computer. It didnt take long before some geniuses realized that the device could do much more than watch TV. With a small change to the driver on your computer, it allowed the users to adjust the frequency that the device filtered into. It also allows the device to sweep through every frequency and display the amplitude of the signal at all of the frequencies like a spectrum analyzer.
Here is their homepage: http://www.rtl-sdr.com/about-rtl-sdr/
I plan on plugging in the antenna to this device and using an FM transmitter to measure the signal strength at various angles of the fiero with the antenna in various orientations. Ogre is right, there is a lot of BS out there, hopefully having real data will debunk some of this. Who knows, we may be surprised with the results.
Report this Post01-13-2015 09:39 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
thanks
please use [img thumb] not [img] for big pictures.
Total ratings: 466
Report this Post01-13-2015 11:33 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Interesting stuff. If you feel so inclined, you might like to start a thread in O/T to discuss this further. A few of the guys who hang out there might enjoy hearing what you can do with this inexpensive technology.
PaulJK
Total ratings: 237
Report this Post01-14-2015 09:15 PM Click Here to See the Profile for PaulJKSend a Private Message to PaulJKEdit/Delete MessageReply w/QuoteDirect Link to This Post
From my experience, this was a bad idea. You're putting the antennae behind metal which shields radio reception. I tried it while i was in Los Angeles (many strong stations/signals) and noticed a definite loss of reception. My preference was to move the antenna to the rear quarter where it looked better (to me). You can also get a Dakota Digital electronic antenna and hide it in the roof under the headliner - worked well in my other car. Dakota Digital stuff is over-priced but works.
http://www.dakotadigital.co...mode=prod/prd105.htm
couldahadaV8
Report this Post01-15-2015 02:15 PM Click Here to See the Profile for couldahadaV8Click Here to visit couldahadaV8's HomePageSend a Private Message to couldahadaV8Edit/Delete MessageReply w/QuoteDirect Link to This Post
The '60's??? Porsche was still using it on their 2007 911's. Reception was certainly not as good as an external antenna.
slicknick
Report this Post01-25-2015 09:10 AM Click Here to See the Profile for slicknickSend a Private Message to slicknickEdit/Delete MessageReply w/QuoteDirect Link to This Post
For the record, my parent's '79 Cutlass had the windshield antenna.
Anyhow, how about under the center of the hood? There's not a lot of metal there.
Total ratings: 461
Report this Post01-25-2015 12:26 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
...Spectrum analyzers...
I'm quite familiar with them. Not something that average persons (or even a lot of 2 way radio shops) have on hand.
Obviously you have some background.
THANK YOU for sharing the info about the receiver. That's pure gold.
Not that I have a lot of need for a spectrum analyzer these days, but it's nice to know that it's out there. Good show!
I'm curious what you do for a living or hobbies. Sounds like you've had more than a basic introduction to RF.
I was thinking that my dad's '68 Bel Air had a windshield antenna. Came out about the same time as hide-a-way wipers. We were impressed with how well it didn't work. (Remember... This was on the AM band, back then.)
I was curious... Craigslist shows a few '68s with no antenna on the fender, so I have to believe that I'm remembering correctly.
Anyway...
Matthew_Fiero
Total ratings: 51
Report this Post07-18-2024 10:14 AM Click Here to See the Profile for Matthew_FieroSend a Private Message to Matthew_FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Since I have my roof panel off I would like to run a wire up and remove the antenna. Should I just remove the base from the car and jam the antenna itself in a pillar or run a standard 14 gauge wire or coathanger that is also somehow connected to the antenna base?
Total ratings: 328
Report this Post07-18-2024 10:36 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Years back a Fiero owner named John White wrote an article on hiding the antenna. He owned a GT with a sun roof. He ran a wire up and used the sunroof frame as the antenna and said it worked well..
KennyG
Report this Post07-18-2024 03:09 PM Click Here to See the Profile for KennyGSend a Private Message to KennyGEdit/Delete MessageReply w/QuoteDirect Link to This Post
I put a cheap "hidden windshield" antenna on the cowl under back edge of the front hood. It was easy to route the cable back into the car in the same path as the original. It works fine and was really simple.
pmbrunelle
Total ratings: 63
Report this Post07-18-2024 06:56 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I used an insulated wire + ring terminal hidden beneath the A-pillar plastic of a Saturn S-Series.
FM reception was somewhat worse than with the stock whip antenna, but still quite usable in a suburban area with transmitters about 10 miles away.
I don't remember there being too much of a blind spot behind the car, which I was expecting with the antenna hidden behind the A-pillar.
Report this Post07-18-2024 07:30 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
I strip some wire to make loop to hook the screw in the base. 20-22 AWG
then w/ P-side door open push the wire from back of fender to hook the screw.
Then put something to keep the loop on the base while I bend the wire as pushed under Windshield trim.
If careful can bend & push the wire at bottom to totally hide from view to "jump over" the A pillar.
I don't even have a nut on the base, just bit of tension to hold & make contact. that's after 20+ years ago.
Wire size doesn't matter much. Does need insulated wire because might touch the frame @ some point.
In the gap along the glass puts a small space between frame & wire so wire isn't shielded so gets most channels that OE antennas get.
You may not want it under the roof panel. The panel is F-glass but paint on it may reduce/block the signal. Have the wire right on the frame won't help too.
CSM842M4
Report this Post07-19-2024 09:00 PM Click Here to See the Profile for CSM842M4Send a Private Message to CSM842M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Just my $0.02 here - I made a bracket out of flat steel that mounts in the location of the stock bracket, folds down into the cavity between the fender and space frame, then points the antenna forward and over the arch of the wheel well. I pre-curved a replacement mast, covered it with Tygon fuel hose and mounted it to the bracket. Haven't tried it with the radio yet, but the physical installation is pretty clean. Used plenty of pasteboard boxes as templates to get everything so that I was happy with it.
Total ratings: 328
Report this Post08-07-2024 08:48 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I ordered a "hidden antenna" and will go this route. It should work under a fiberglass hood and with no metal in the way. You can find them on eBay and they are not expensive.
