  Dim Headlights
Dim Headlights by Joker-1986
Started on: 12-27-2014 08:44 PM
Replies: 5 (222 views)
Last post by: theogre on 12-28-2014 10:57 AM
Joker-1986
Report this Post12-27-2014 08:44 PM Click Here to See the Profile for Joker-1986Send a Private Message to Joker-1986Edit/Delete MessageReply w/QuoteDirect Link to This Post
1986 GT Fiero. I purchased this about a year ago and had not driven much at night. Figured I needed new headlights. I replaced them and even put in HID lights but the light is still dim. I can onlt see a foot in front of the car.
Anyone else dealt with this or have some suggestions of where I can start?
If I missed a previous discussion....
tshark
Report this Post12-27-2014 09:07 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Shho13
Report this Post12-27-2014 09:09 PM Click Here to See the Profile for Shho13Send a Private Message to Shho13Edit/Delete MessageReply w/QuoteDirect Link to This Post
Check the grounds... There is a write up about adding a new ground on to the engine to fix several electrical gremlins...
https://www.fiero.nl/forum/Forum2/HTML/043240.html
Edit: Check obvious things like alternator output. Use a multi meter, the gauge isn't all that accurate. it should be about 14v with the car running.
I also agree tshark, the wiring is old, check the ohm readings, dim lights anywhere means there is high resistance somewhere in the circuit... Ohm out the wire from the bulb back to the various other locations... if you find high resistance, look for corrosion on terminals first before going crazy looking through the harness; simple corrosion on terminals is usually what causes high resistance.
"Discord"
( ͡° ͜ʖ ͡°)
[This message has been edited by Shho13 (edited 12-27-2014).]
petehiggins75
Report this Post12-27-2014 10:11 PM Click Here to See the Profile for petehiggins75Click Here to visit petehiggins75's HomePageSend a Private Message to petehiggins75Edit/Delete MessageReply w/QuoteDirect Link to This Post
Could be voltage regulator.my alternator is about to crap out on me,poof!just like that.take your car to advance auto or something,they can put their computer on ur battery and do a load test like on my duke or just start ur car and pull the negative cable ans see what happens,hope this helps
tshark
Report this Post12-28-2014 07:38 AM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Report this Post12-28-2014 10:57 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Start at See my Cave, Headlights and Wire Service
