  Need a pic showing an LSx swap-in and shock towers
Need a pic showing an LSx swap-in and shock towers by 85-308
Started on: 12-05-2014 04:46 PM
Replies: 13 (269 views)
Last post by: 85-308 on 12-05-2014 08:53 PM
85-308
Report this Post12-05-2014 04:46 PM Click Here to See the Profile for 85-308Send a Private Message to 85-308Edit/Delete MessageReply w/QuoteDirect Link to This Post
this turns out to be a bit difficult to search for. I'm looking for a clear pic, straight across the rear shock towers, and showing an LSx engine in place.
Preferably looking down a 'bit' into the engine compartment to show the rear extremity of the engine to some extent.
The reason is I need to plan my new rear suspension and need a good idea of what interference I may run into along the line between the top strut mount points.
If the shot is on an angle it might not give the sense of space - or lack thereof...
Any shots or links appreciated! Thanks in advance;
GP
1fast2m4
Report this Post12-05-2014 05:19 PM Click Here to See the Profile for 1fast2m4Send a Private Message to 1fast2m4Edit/Delete MessageReply w/QuoteDirect Link to This Post
I don't have a pic but I wanted to clarify LS4 or LQ4/9 & LS1/2/3/6//9?
The LS4 has a revised front and a starter up top for a tighter FWD fitment.
Report this Post12-05-2014 05:36 PM Click Here to See the Profile for 85-308Send a Private Message to 85-308Edit/Delete MessageReply w/QuoteDirect Link to This Post
thanks for asking; it is an LS4 but the width (due to transverse mounting) becomes the issue, so I don't really care which one is shown..
altho in a perfect world.... it would be an LS4 with an F40 trans from a G6! ;-)
So the pic would be from one side to the other, hopefully showing the line of the strut top mounting points and 'some' engine.
dobey
Total ratings: 371
Report this Post12-05-2014 05:53 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
The LS4 doesn't really save any space, even with not having to use an adapter plate. The changes the LS4 has to fit better in a FWD car are for the FWD platform, and not the Fiero. The block isn't any smaller than any other LSx engine. The big pattern LSx engines have the starter on the front side as well, so it doesn't affect the strut tower side of the engine.
dobey
Total ratings: 371
Report this Post12-05-2014 05:55 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
dobey
Member since Sep 2001
Report this Post12-05-2014 06:05 PM Click Here to See the Profile for 85-308Send a Private Message to 85-308Edit/Delete MessageReply w/QuoteDirect Link to This Post
"...The LS4 doesn't really save any space, even with not having to use an adapter plate. The changes the LS4 has to fit better in a FWD car are for the FWD platform, and not the Fiero. The block isn't any smaller than any other LSx engine. The big pattern LSx engines have the starter on the front side as well, so it doesn't affect the strut tower side of the engine...."
Yes; that part I know. My issue is rebuilding the rear shocks/suspension. The pic is good; wonder what the bit of blue is at the very top of the pic?
Thanks; good find.
GP
ericjon262
Report this Post12-05-2014 06:49 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
well, it's over 2 3/8" shorter LOA, which minimizes any frame cutting that would have to take place, which to me, is a big deal. IIRC, fieroguru's LS4/F40 seap didn't require a frame notch at all.
Report this Post12-05-2014 07:13 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
All current RWD LS(x) engine swaps (Except Don Kraus's) do use a much thicker adapter plate and a balancer that protrudes much further.
However, a RWD LS(x) engine "could" be installed with a 3/16" thick adapter plate to attach the F40 and have the same overall length as my LS4/F40. It would require a 142 tooth flywheel and a transmission mounted starter... but so does the LS4/F40.
ericjon262
Report this Post12-05-2014 07:25 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
I was under the impression that the LS4 front drive made the engine shorter as well. but I guess that could be swapped to the other LSx engines as well.
dobey
Total ratings: 371
Report this Post12-05-2014 07:28 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
The blue at the top of the pic is just lighting causing a reflection off the other strut tower.
Report this Post12-05-2014 07:30 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Next week if I can get to the apartment over lunch or get there before its dark, I can take and post the picture you need.
If you are looking for rear suspension ideas, check this thread out:
https://www.fiero.nl/forum/F.../HTML/000116-22.html
Its a great thread to read start to finish!
[This message has been edited by fieroguru (edited 12-05-2014).]
dobey
Total ratings: 371
Report this Post12-05-2014 07:32 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
The crankshaft is slightly shorter, and puts the belt drive slightly closer to the engine. The casting for the metric bell pattern makes the rear of the block slightly thicker as well.
So you don't need to notch the frame for the accessory drive, but the head on the rear side still will be fairly close to the passenger side strut mount tower, the oil fill neck will still come up next to it, and the straight line interference across the top of the strut towers, is roughly the same.
Report this Post12-05-2014 07:35 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, the LS4 accessory drive is more compact, but its a bolt on swap to the RWD blocks w/o any machining (just needs a large washer for the balancer bolt on the crankshaft). Many of the Porsche LS(x) kits are now using the LS4 balancer on the RWD blocks.
Report this Post12-05-2014 08:53 PM Click Here to See the Profile for 85-308Send a Private Message to 85-308Edit/Delete MessageReply w/QuoteDirect Link to This Post
"...https://www.fiero.nl/forum/Forum3/HTML/000116-22.html ..."
I will make a point of it! what a drawing! Is this from someone's actual measurements? I'll have to read, obviously, but the important issues become what is the trans that is being shown; for the axle attachment points?
No answer req'd at least right now; I'll read that thread!
Thanks Fieroguru!
