  84 fan problem
84 fan problem by sgosser
Started on: 11-06-2014 10:30 AM
Replies: 2 (136 views)
Last post by: Patrick on 11-06-2014 04:48 PM
sgosser
Report this Post11-06-2014 10:30 AM Click Here to See the Profile for sgosserSend a Private Message to sgosserEdit/Delete MessageReply w/QuoteDirect Link to This Post
hey all, I have a couple of strange problems maybe someone can help me with. 84 fiero the po had the radiator fan wired with a toggle switch. there was not the correct sensor on the motor to put it back like it should be, so i bought a relay kit with a probe switch for the radiator. The fan comes on but is blowing in my face. I think it was wired backwards at the motor. It is just a dc motor so i should be able to swap the wires on the motor. Is that correct? My other problem is not a fiero, it's a 97 astro van. The radio started picking up in and out, lots of static. I tried a new antenna, but it did not work. I did notice when the antenna is close to but not touching the mounting screw, it picks up perfect. Maybe a bad ground??? I kinda stumped on that one. thanks for any help
Scott
TONY_C
Report this Post11-06-2014 11:23 AM Click Here to See the Profile for TONY_CSend a Private Message to TONY_CEdit/Delete MessageReply w/QuoteDirect Link to This Post
The fan is supposed to draw air through the radiator so, assuming you are standing behind the fan, you should have air blowing at you.
Report this Post11-06-2014 04:48 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well geez, that really tells us a lot. Where's your face in relation to the rad?
