  Where do you check the fuel pressure on the 85 fiero 2.5
Where do you check the fuel pressure on the 85 fiero 2.5 by chrislayton
Started on: 11-05-2014 10:14 AM
Replies: 2 (824 views)
Last post by: mckaymotoworks on 11-05-2014 10:35 AM
chrislayton
Report this Post11-05-2014 10:14 AM Click Here to See the Profile for chrislaytonSend a Private Message to chrislaytonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've got a fuel pressure gauge. Never used it before but where do you connect in to the fuel system of the 85 fiero 2.5 liter engine? I don't see a shrader valve or anything to connect into unless I'm looking in the wrong place. What should the pressure be?
Report this Post11-05-2014 10:25 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
mckaymotoworks
Report this Post11-05-2014 10:35 AM Click Here to See the Profile for mckaymotoworksClick Here to visit mckaymotoworks's HomePageSend a Private Message to mckaymotoworksEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Gall757:
https://www.fiero.nl/forum/Forum2/HTML/127190.html
http://home.comcast.net/~fierocave/tbiadaptor.htm
Chris, as Gall provided above. You can rent the kit from O'Reilly's for $100 refundable deposit. Follow Ogre's steps, just goes inline where fuel filter goes, makes sure it's tight but not over tightened to A. not leak fuel B. damage threads. You'll want to test at Idle and under Load (driving) Works best to have a passenger watch the gauge making notes with it taped to the back window.
