  7730 Evap Purge Solenoid Vacuum Routing
7730 Evap Purge Solenoid Vacuum Routing by onesexyfiero
Started on: 10-11-2014 06:48 PM
Replies: 1 (161 views)
Last post by: Blacktree on 10-12-2014 10:16 AM
onesexyfiero
Report this Post10-11-2014 06:48 PM Click Here to See the Profile for onesexyfieroSend a Private Message to onesexyfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nevermind. Found it deep in Darth's thread. In case anyone searches and finds this thread, answer is:
Abandon the vacuum line at the throttle body.
Connect the two lines on the canister (excluding the one to the tank) together
Run the two of those combined to the solenoid "can" port
Connect the other port of the solenoid to the intake
[This message has been edited by onesexyfiero (edited 10-11-2014).]
Blacktree
Total ratings: 350
Report this Post10-12-2014 10:16 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yep, that's what I did on mine. You no longer need a separate vacuum line to activate the valve in the charcoal canister. So you just put a Y-fitting on the canister to merge the two lines, run a line from the Y-fitting to the solenoid, and connect the solenoid to manifold vacuum.
[This message has been edited by Blacktree (edited 10-12-2014).]
