  electric wooes
electric wooes by LorenBateman
Started on: 09-14-2014 10:17 PM
Replies: 6 (180 views)
Last post by: LorenBateman on 09-15-2014 03:37 PM
LorenBateman
Report this Post09-14-2014 10:17 PM Click Here to See the Profile for LorenBatemanSend a Private Message to LorenBatemanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thinking this might be a bad ground, but hoping someone could point me in the right direction..Have an 88GT, when i hit the blinkers the tach starts to flicker a little,,when the head lights are turned on the tach just goes nuts,,as well as the fuel gauge
NetCam
Report this Post09-14-2014 10:58 PM Click Here to See the Profile for NetCamClick Here to visit NetCam's HomePageSend a Private Message to NetCamEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds like a bad ground to me, and going through all your grounds and cleaning them up can never really be a bad thing can it?
LorenBateman
Report this Post09-14-2014 11:33 PM Click Here to See the Profile for LorenBatemanSend a Private Message to LorenBatemanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yep ,,this will be what i end up doing,,was hoping someone would know which one to start with
NetCam
Report this Post09-14-2014 11:42 PM Click Here to See the Profile for NetCamClick Here to visit NetCam's HomePageSend a Private Message to NetCamEdit/Delete MessageReply w/QuoteDirect Link to This Post
There's still a chance of that, lots of real smart folks on this forum, not least of which is Phonedawgz who seems to know wiring as well as anybody.
Total ratings: 291
Report this Post09-14-2014 11:43 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks
This is most likely your problem
https://www.fiero.nl/forum/Forum2/HTML/043240.html
Bloozberry
Total ratings: 311
Report this Post09-15-2014 07:03 AM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
The FSM shows that the tach and the fuel gauge share the same grounding point namely G201:
G201 is located behind the radio. It will look like a single black wire with an eyelet attached to a black vertical metal beam that supports the center of the dash. In reality, that one wire leads back to a splice called S212 which has 16 black wires going into it, one of them leads to the tach and fuel gauge. If you follow the single wire from G201 into the harness towards the driver's footwell, you'll find S212 buried about 6 inches in. It will look like an octopus of black wires covered in electrical tape. Sometimes the acidic solder paste that was used begins to break down the splice connection and gives problems. Since nothing else is acting up, that's where I'd start.
LorenBateman
Report this Post09-15-2014 03:37 PM Click Here to See the Profile for LorenBatemanSend a Private Message to LorenBatemanEdit/Delete MessageReply w/QuoteDirect Link to This Post
you folks are amazing..TY for all the help
