  Ed Parks 4.9 wiring harness mystery
Ed Parks 4.9 wiring harness mystery by paulcal
Started on: 09-01-2014 10:56 AM
Replies: 4 (841 views)
Last post by: paulcal on 09-01-2014 08:48 PM
paulcal
Total ratings: 96
Report this Post09-01-2014 10:56 AM Click Here to See the Profile for paulcalSend a Private Message to paulcalEdit/Delete MessageReply w/QuoteDirect Link to This Post
While under the car today I noticed a loose red wire with a large round terminal connector on it. Upon further inspection I also found a smaller purple wire coming out of the same bundle that was not connected to anything either. These are run along the front injector rail. They look like they should be connected to something...
[This message has been edited by paulcal (edited 09-01-2014).]
paulcal
Total ratings: 96
Report this Post09-01-2014 11:24 AM Click Here to See the Profile for paulcalSend a Private Message to paulcalEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok, I just traced the big red wire back through the harness to the bottom of the alternator, "S" is what's labled on the connection so I assume starter? It's possible I didn't connect it when I changed out the starter to the Allente starter. Still trying to track down the purple one.
The rest of the connections on the alternator are: The single pole on the top of the backside has a red wire going to the terminal block under the C-500 and from there it goes to the battery connection on the back of the starter. Should the red wire I found go to the battery connection of the starter?
ericjon262
Report this Post09-01-2014 03:26 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
sounds like starter connections, purple usually comes from the neutral safety switch...
Total ratings: 290
Report this Post09-01-2014 06:23 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Purple - Starter solenoid
Big Red - Starter battery cable connection - Connects to the output of the alternator on the other end. There is also the little pigtail that runs to the S (battery sense) terminal of the alternator's connector.
[This message has been edited by phonedawgz (edited 09-01-2014).]
paulcal
Total ratings: 96
Report this Post09-01-2014 08:48 PM Click Here to See the Profile for paulcalSend a Private Message to paulcalEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Phonedawgz. It looks like the reason I didn't connect it was due to the Allente starter terminals being farther away from the harness than the stock 4.9 starter. I lengthened the red wire and connected it.
