  already tried a search 3800SC
already tried a search 3800SC by Lou6t4gto
Started on: 08-13-2014 01:55 PM
Replies: 4 (133 views)
Last post by: MulletproofMonk on 08-13-2014 07:44 PM
Lou6t4gto
Report this Post08-13-2014 01:55 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
already did a search, maybe wording it wrong. I want to" alter" a 2.8 "Water/ thermostat filler" for use on my 3800SC. anyone got a Link for doing that ? Thanks
Lou6t4gto
Report this Post08-13-2014 02:02 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
AND, can this thermostat Housing be used if the SC "bypass" is still on there ?!
gtoformula
Report this Post08-13-2014 02:36 PM Click Here to See the Profile for gtoformulaSend a Private Message to gtoformulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here's a link to a forum member who was offering these.
https://www.fiero.nl/forum/Forum4/HTML/056178.html
Lou6t4gto
Report this Post08-13-2014 03:07 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
again, it shows WITHOUT the SC bypass.
MulletproofMonk
Total ratings: 78
Report this Post08-13-2014 07:44 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
1. I don't think Dave does the thermostats anymore. His business is more profitable then Fiero's (good for him, bad for us). I have one and it didn't fit with the boost bypass so I made my own.
2. I will see if I can find the picture later, it is in someones build thread. Basically cut the base and rotate it so the hose outlet is pointed towards your coolant hose. After that you slot the holes so that your bolts fit.
-Brian
Removing the roof panel
My HUD install thread
Modified stock air canister and base to 3.5 inch for 3800na
