  Carb V8 guys, what throttle bracket are you running?
Carb V8 guys, what throttle bracket are you running? by Apricot Punt
Started on: 05-21-2014 11:10 AM
Replies: 2 (117 views)
Last post by: Archie on 05-21-2014 04:54 PM
Apricot Punt
Report this Post05-21-2014 11:10 AM Click Here to See the Profile for Apricot PuntSend a Private Message to Apricot PuntEdit/Delete MessageReply w/QuoteDirect Link to This Post
So I went and picked up a 20 dollar Mr. Gasket throttle bracket, and noticed the other day the stupid thing bends when you depress the pedal. I have been looking at the kind that have two eyelits that secure to carb base. Summit and Jegs don't have very good pictures and descriptions to tell if they're the square type detent that I am looking for. Some of them say "GM style throttle". Does this mean small square detent for the throttle? or the large square detent for the kickdown? or something completely different that is on the older muscle cars? Thanks in advance.
woodyhere
Report this Post05-21-2014 03:22 PM Click Here to See the Profile for woodyhereSend a Private Message to woodyhereEdit/Delete MessageReply w/QuoteDirect Link to This Post
I used a GM part from a carbed V8 car. It had the square hole the Fiero cable fit in. I had to do a little fab work on the plate because it didn't match my flange. It' s stamped steel and has reinforcements stamped in it. Might be a good idea to take a trip to the local you-pull-it. Could you reinforce the one you already have?
woodys 427
Archie
Total ratings: 547
Report this Post05-21-2014 04:54 PM Click Here to See the Profile for ArchieClick Here to visit Archie's HomePageSend a Private Message to ArchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
I use an Edelbrock EDE8030
