  Where to buy ???
Where to buy ??? by Lou6t4gto
Started on: 05-18-2014 07:31 PM
Replies: 7 (232 views)
Last post by: Jason88Notchie on 05-19-2014 01:53 PM
Lou6t4gto
Report this Post05-18-2014 07:31 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Anyone know of a place that sells "Sheets" of Fiberglass ??? Thanks
84fiero123
Total ratings: 325
Report this Post05-18-2014 07:41 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
You didn't say how big or thick,
http://www.homedepot.com/b/...-Panels/N-5yc1vZbqk5
Steve
Lou6t4gto
Report this Post05-19-2014 12:08 AM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
about 3/16"-1/4" FIBERGLASS, for making Body Panels. what home depot has is not much more than cheap plastic.
Lou6t4gto
Report this Post05-19-2014 12:14 AM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lou6t4gto
Member since May 2008
it looks like what "CAR-LO" ( https://www.fiero.nl/forum/F.../HTML/000129-10.html ) is using to make his panels. I sent him a PM, and asked where he got it, did not get an answer.
rogergarrison
Total ratings: 551
Report this Post05-19-2014 07:23 AM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Contact a boat or RV repair facility near you. When I did work for a big RV/boat dealer here, they got bulk replacement paneling from the various manufacturers. Some they got was 12'X35' (for a whole side of a motorhome).
Lou6t4gto
Report this Post05-19-2014 12:25 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just got a pm from Car-lo, he says he is using old Fiero HOODS he cut up because they bend both ways. I thought it was fiberglass sheets. I would think fiberglass sheet would be cheaper than buying hoods though, and easily be glassed together. Have to investigate. thanks
dobey
Total ratings: 371
Report this Post05-19-2014 12:40 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
You use the sheets of insulation to build up a base shape to pull a mold from. Then you make a mold, and use that mold to create a real fiberglass part. Or you just skip the mold part, make a one-off fiberglass part, and get rid of the insulation material underneath the finished part.
I don't know why anyone would want to use hoods from a Fiero for that. They are not fiberglass, and not exactly cheap to get. Plus, cutting them up into small bits to make other parts from means fewer actual hoods for people who do need one for their cars.
Jason88Notchie
Report this Post05-19-2014 01:53 PM Click Here to See the Profile for Jason88NotchieSend a Private Message to Jason88NotchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Roger, is there anything you haven't done??
