  1986 4 speed muncie.
1986 4 speed muncie. by zzzhuh
Started on: 05-06-2014 05:21 PM
Replies: 7 (597 views)
Last post by: Custom2M4 on 05-07-2014 12:57 PM
zzzhuh
Report this Post05-06-2014 05:21 PM Click Here to See the Profile for zzzhuhSend a Private Message to zzzhuhEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hope we are all doing well after Cinco de Mayo and are either fully recovered or recovering
On the other hand I am a bit confused about my 86 fiero GT Manual 4 speed muncie. I have read on a few forums that there is a place to check the fluid but I can't seem to find it. There is no dip stick so im assuming you have to remove a sensor or a plug to find it.
I read about the fluid to use but what do you personally use?
Any help regarding this would be much appreciated. Thanks.
The wetter the better
Report this Post05-06-2014 05:33 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
zzzhuh
Report this Post05-06-2014 05:35 PM Click Here to See the Profile for zzzhuhSend a Private Message to zzzhuhEdit/Delete MessageReply w/QuoteDirect Link to This Post
Perfect, thanks man!
Lambo nut
Total ratings: 257
Report this Post05-06-2014 06:42 PM Click Here to See the Profile for Lambo nutSend a Private Message to Lambo nutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Save yourself a possible headache and don't pull the VSS out of the transmission. Use the fill plug on the side of the transmission to refill it instead as noted in the third post of the provided link.
Kevin
Lou and Blue
Report this Post05-06-2014 07:29 PM Click Here to See the Profile for Lou and BlueSend a Private Message to Lou and BlueEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does the shot glass of stp oil treatment work well on the Muncie, I will be replacing the fluid come summertime. I heard Rodney suggest this shot glass of stp oil treatment for the getrag, but I have a Muncie.
Thanks
Louis Duet
Baldwin, Long Island, NY
Where driving hard is SOP.
"Blue" <= '85 Fiero GT
Stock V6---Stock everything. Trying to keep it 'mostly' that way.
"Boo" <= '81 Delorean DMC-12
The "DuetLorean"
VIN #5835
Stock PRV engine
Robertson Equipped
Neiland/Delman Engineered
Carbed and loving it! (Peugot 604 manifold) ---"Sorry purists"
zzzhuh
Report this Post05-06-2014 09:56 PM Click Here to See the Profile for zzzhuhSend a Private Message to zzzhuhEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks
In all honesty those "treatments" are more of a gimmick.
If you feel the need to, by all means go ahead but I doubt it will make much of a difference.
The fluid that is put into the transmission is already of high quality so by putting treatment
in your more or less just putting more of the same in there.
[This message has been edited by zzzhuh (edited 05-06-2014).]
chetw77cruiser
Report this Post05-06-2014 11:03 PM Click Here to See the Profile for chetw77cruiserSend a Private Message to chetw77cruiserEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent.
Custom2M4
Total ratings: 114
Report this Post05-07-2014 12:57 PM Click Here to See the Profile for Custom2M4Send a Private Message to Custom2M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
If I recall correctly the "high quality" fluid is 5w30. Guys usually switch it to synchromesh, which wouldn't require a treatment.
