  My Windshield wipers won't turn off.
My Windshield wipers won't turn off. by Dotrenrew
Started on: 04-29-2014 11:11 PM
Replies: 3 (482 views)
Last post by: 84fiero123 on 04-30-2014 08:40 AM
Dotrenrew
Report this Post04-29-2014 11:11 PM Click Here to See the Profile for DotrenrewClick Here to visit Dotrenrew's HomePageSend a Private Message to DotrenrewEdit/Delete MessageReply w/QuoteDirect Link to This Post
They just keep going and going and going and...
If I fiddle with the switch just right, I can get them to shut off for a little while but they just wanna keep going and going and going and...
Please help.
2002 Audi Allroad. Tip. 100% Natural. (FOR SALE)
2011 VW Golf. (Wife's Wheels)
2002 VW Jetta (FOR SALE)
1984 Pontiac Fiero 4 speed Duke.
Total ratings: 466
Report this Post04-29-2014 11:49 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pull the fuse (for now)... unless you're driving in the rain.
seajai
Total ratings: 52
Report this Post04-30-2014 12:47 AM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds like the switch is bad. I just replaced one last weekend for a similar issue where the wipers would make a pass or two if the lever was bumped. Unplug the switch under the dash and see if the wipers stop, if they do I'd replace the switch.
84fiero123
Total ratings: 325
Report this Post04-30-2014 08:40 AM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ditto and order or pickup a switch, they are the same for many year GM products over the same decade the Fieros were built so they should still be readily available still. one thing I will add is try with the car off rotating the switch several times or more, sometimes it is just a dirty switch due to lack of use and others the contacts are worn out, if its just dirty repeated turning of the switch may clean it enough for it to start working, if not just put a new one in.
one hint on how to replace it as simply as possible, tie a peace of thin wire to the plug at the bottom of the steering wheel shaft when removing the plug. that way when you put the new wire back in you can just pull it down to the original position when you reinstall the new one.
Steve
