  Spare Tire tub removal - brake line clips
Spare Tire tub removal - brake line clips by Ravant
Started on: 04-16-2014 12:26 AM
Replies: 4 (857 views)
Last post by: Patrick on 04-17-2014 01:12 PM
Ravant
Report this Post04-16-2014 12:26 AM Click Here to See the Profile for RavantSend a Private Message to RavantEdit/Delete MessageReply w/QuoteDirect Link to This Post
As the title insinuates, how do I undo these infuriating things?!
Edit: never mind. First one broke. Second was so dry-rotted it just crumbled away.
[This message has been edited by Ravant (edited 04-16-2014).]
Report this Post04-17-2014 02:30 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just so you know for next time... use a dremel and grind the head of the rivet off.
84fiero123
Total ratings: 325
Report this Post04-17-2014 07:57 AM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
you can also just drill the rivets out with a drill bit, as well as if you have clips that just are to far gone to reuse again hardware stores sell strapping with predrilled holes in them by the roll for hanging water pipes in homes. just cut the inch or so you need to make a new clip wrap it around the line in the place you need them. dealers also still sell these clips by the package while more expensive they are all just about the same over the last few decades and some even have a rubber type wrap, inside that prevents damage of the steel line from chaffing.
Steve
Orig88GT-NC
Report this Post04-17-2014 11:35 AM Click Here to See the Profile for Orig88GT-NCSend a Private Message to Orig88GT-NCEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by 84fiero123:
....... dealers also still sell these clips by the package while more expensive they are all just about the same over the last few decades and some even have a rubber type wrap, inside that prevents damage of the steel line from chaffing.
I use these types of clamps all over my car , there great for securing a lot of things, ie. Brake Lines, Wire Harnesses and Vacuum lines .
Their used on aircraft and are called (ADEL-CLAMPS) very common items, and not that expensive if you shop the internet.
They come in all sizes from 1/8" to well over 3" in diam. and are general made in Alum or stainless steel...
sizes are marked with a dash number at the end of their part number in 16ths of an inch. DG-2 = (1/8" clamp), a DG-4 = (1/4" clamp)
Bob,
Report this Post04-17-2014 01:12 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
you can also just drill the rivets out with a drill bit...
It's not always that easy. Often the rivets will just spin. I find that grinding the head of the rivet off works first time every time... and it takes about ten seconds.
