  AC Compressor Compatability
AC Compressor Compatability by jpeeler
Started on: 03-24-2014 08:46 PM
Replies: 3 (217 views)
Last post by: jpeeler on 03-25-2014 11:54 AM
jpeeler
Report this Post03-24-2014 08:46 PM Click Here to See the Profile for jpeelerSend a Private Message to jpeelerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Would the AC compressor in this craigslist ad work on my gf's '87 GT? We want to convert it to 134a after we get done sanding it and have it painted.
http://greensboro.craigslis.../pts/4329752152.html
mitchjl22
Report this Post03-25-2014 01:37 AM Click Here to See the Profile for mitchjl22Send a Private Message to mitchjl22Edit/Delete MessageReply w/QuoteDirect Link to This Post
That uses a serpentine style ribbed belt, our compressors use a different kind. I don't know how easy it is to switch the clutches, but you could look into it.
-Mitch
RWDPLZ
Total ratings: 305
Report this Post03-25-2014 02:04 AM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
That compressor isn't clocked properly for a Fiero. You want one with the ports oriented like this:
It would have to be completely disassembled and resealed with new body O-rings. It would also need to be reassembled with the Fiero's 2-port rear head, to keep both switches. The one on craigslist only has one switch port.
https://www.fiero.nl/forum/Forum2/HTML/124630.html
The pulley would also have to be swapped to a v-belt style, which isn't difficult with the right specialty tools. So would the clutch coil, or just swap the connector on your car to the new style.
It also DOES appear to be a reman-ed compressor, not new as advertised.
jpeeler
Report this Post03-25-2014 11:54 AM Click Here to See the Profile for jpeelerSend a Private Message to jpeelerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oh well could have been a good deal. Thanks for the replies. +'s given.
