  New gapped plugs, wires and cap. Will not start.
New gapped plugs, wires and cap. Will not start. by FieroCat
Started on: 03-15-2014 01:55 PM
Replies: 11 (332 views)
Last post by: 84fiero123 on 03-16-2014 12:07 PM
FieroCat
Report this Post03-15-2014 01:55 PM Click Here to See the Profile for FieroCatSend a Private Message to FieroCatEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just did a tuneup, with new plugs, wires, cap. Plugs are gapped properly at .045.
Engine turns but refuses to start. The only concern I had was that there were two coil-to-distributor wires in the kit that I ordered, am I forgetting to connect something? Not sure what it is or I has the dumb...
Fadingaway
Report this Post03-15-2014 01:58 PM Click Here to See the Profile for FadingawaySend a Private Message to FadingawayEdit/Delete MessageReply w/QuoteDirect Link to This Post
Engine? Did you double check the firing order
FieroCat
Report this Post03-15-2014 02:01 PM Click Here to See the Profile for FieroCatSend a Private Message to FieroCatEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, I stupidly removed the old wires before remembering to label which went to which, but I found this diagram and connected the new ones using it for reference:
https://www.fiero.nl/forum/A...020511-2-018190.html
Is this diagram correct?
Fadingaway
Report this Post03-15-2014 02:19 PM Click Here to See the Profile for FadingawaySend a Private Message to FadingawayEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes and no, can you post pictures of where your distributor is facing. You may have got confused best way to do this is make sure your #1 is right and go from there. The position of your number one may be different (visually) from what is shown based off of how the distributor is turned when timing was set
Total ratings: 465
Report this Post03-15-2014 02:44 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Keep in mind that #1 on the distributor cap can theoretically be any of the terminals. That diagram is just a suggestion (that I do follow). You'll have to determine where your rotor is pointed when #1 cylinder is at TDC (of the compression stroke).
FieroCat
Report this Post03-15-2014 02:48 PM Click Here to See the Profile for FieroCatSend a Private Message to FieroCatEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just fixed it. I realized the Haynes manual had the correct configuration and it started right up. My number one terminal on the cap is closest to the engine.
Formula88
Total ratings: 554
Report this Post03-15-2014 03:06 PM Click Here to See the Profile for Formula88Send a Private Message to Formula88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Today's Lesson: Change plug wires one at a time.
Total ratings: 465
Report this Post03-15-2014 03:42 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Glad that makes sense to you.
FieroCat
Report this Post03-15-2014 03:47 PM Click Here to See the Profile for FieroCatSend a Private Message to FieroCatEdit/Delete MessageReply w/QuoteDirect Link to This Post
Closest to the passenger side?
Total ratings: 465
Report this Post03-15-2014 04:19 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
The bolt indicated with the arrow is pretty close to where I line up the #1 terminal (and rotor) with TDC before I time the engine.
[This message has been edited by Patrick (edited 03-15-2014).]
rogergarrison
Total ratings: 551
Report this Post03-15-2014 06:23 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Great advice I ALWAYS follow with no exception. I also label any wires I disconnect with masking tape and a pen. A great invention for someone to make is a kit that has permanent snap on (like loom) labels for everything under a hood. I had them for spark plug wires on several cars I bought at Jegs. Ive bought wire kits for car restorations that had every wire permanently labeled with what it went to and wondered why no one makes them separately.
84fiero123
Total ratings: 325
Report this Post03-16-2014 12:07 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
A rule I have followed religiously for the last 40+ years that has never failed me. I did have a friend call me one morning at 7 AM, 7 AM I was working the night shift the night before and did some overtime so I hadn't gotten home until 4 AM he called and asked me what the firing order was on his car, WTF. I told him it was on the intake manifold, he said he couldn't find it, so I looked it up read it to him and then went back to bed. he called me again a few hours later saying it still wouldn't start, I described the cap shape and hold down screws in relation to number 1 plug and again gave him the firing order. Go by the cap and the screws relationship to number 1 and you should never be wrong, unless the manual is wrong. I have only run into that once, in a Haynes manual on an Astro van. but it does happen, I had to look the firing order up online to realize it was wrong in the manual.
so in all the time I have ever changed plugs, unless it was a complete engine rebuild I have only messed up that one time, because I only change one plug at a time.
Factory wire sets used to have them on them as well Roger, remember them, I know you do, was for ease of assembly at the factory. If I remember right it was printed right on the wirers and the cap.
Steve
[This message has been edited by 84fiero123 (edited 03-16-2014).]
