  After dropping cradle, Idle at 2100rpm and code 35
After dropping cradle, Idle at 2100rpm and code 35 by mitchjl22
Started on: 03-10-2014 01:29 AM
Replies: 4 (241 views)
Last post by: mitchjl22 on 03-15-2014 01:46 AM
mitchjl22
Report this Post03-10-2014 01:29 AM Click Here to See the Profile for mitchjl22Send a Private Message to mitchjl22Edit/Delete MessageReply w/QuoteDirect Link to This Post
I just finished re-installation of the cradle last week, only to discover that his engine was idling extremely high. I took it for a drive around the block (found I had a huge exhaust leak) and let it get to normal op temp. I pulled into the driveway and received a code 35, the car had a 23, I just forgot to plug in the MAT sensor. Checked for VAC leaks, EGR solenoid and Valve connected, EVAP connected, Cruise control connected, and I have power brakes... hmmm
Less than 50k miles, 2.8, 4spd 86gt
Some strange wire was broken off when I dropped the cradle, and oddly enough, somebody else posted something that indicated they had a snipped o2 ground wire, that seems like that what's missing on this car.
Does anyone else have any suggestions on what could be happening?
-Mitch
tesmith66
Total ratings: 135
Report this Post03-10-2014 07:14 AM Click Here to See the Profile for tesmith66Send a Private Message to tesmith66Edit/Delete MessageReply w/QuoteDirect Link to This Post
Fix the broken wire for starters.
Check EVERYWHERE and make sure no other wires are pinched or broken. Also make sure everything is plugged in, Reseat all of the connectors if you have to. Ensure the engine is grounded to the frame, not the cradle. After all of that, clear all codes and see if they come back.
1986 SE Aero coupe.
mitchjl22
Report this Post03-10-2014 03:12 PM Click Here to See the Profile for mitchjl22Send a Private Message to mitchjl22Edit/Delete MessageReply w/QuoteDirect Link to This Post
Okay thanks, where does this o2 sensor ground connect? I just did my 3800sc swap, and I'm 99.99999% sure I didn't have that ground strap on my car.
-Mitch
My Car - 87' GT 3800sc
https://www.fiero.nl/forum/F.../HTML/121571.html#p0
tesmith66
Total ratings: 135
Report this Post03-11-2014 07:02 AM Click Here to See the Profile for tesmith66Send a Private Message to tesmith66Edit/Delete MessageReply w/QuoteDirect Link to This Post
The single wire O2 sensor grounds through the engine like a park plug. Make sure the engine has a good ground to the same structure the battery - is grounded to.
mitchjl22
Report this Post03-15-2014 01:46 AM Click Here to See the Profile for mitchjl22Send a Private Message to mitchjl22Edit/Delete MessageReply w/QuoteDirect Link to This Post
