  Rebuilt fuel sender, sealing fuel lines atop tank, and that brass ball
Rebuilt fuel sender, sealing fuel lines atop tank, and that brass ball by notaguru
Started on: 03-05-2014 02:12 PM
Replies: 0 (398 views)
Last post by: notaguru on 03-05-2014 02:12 PM
notaguru
Report this Post03-05-2014 02:12 PM Click Here to See the Profile for notaguruClick Here to visit notaguru's HomePageSend a Private Message to notaguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
'88GT
I've just installed a new fuel pump, and rebuilt the fuel sender using a robust 0-90 ohm potentiometer removed from this assembly on eBay: http://tinyurl.com/qxehzqn and $22 shipped! I'll be glad to send photos to anyone that is interested, but can't seem to post here...
The metal fuel lines enter the tank through the cap. It appears that there is slight play in two of those tubes. Should they be welded? Sealed with JB or silicone?
ALSO, on the inside of the cap there's a check valve plus brass ball, in a cage. Is that a rollover fire preventer? It is pretty flaky after 26 years. Should I do anything about it?
