  Fuel Tanks
Fuel Tanks by raysr11
Started on: 02-20-2014 02:19 PM
Replies: 3 (153 views)
Last post by: raysr11 on 02-20-2014 04:12 PM
raysr11
Report this Post02-20-2014 02:19 PM Click Here to See the Profile for raysr11Send a Private Message to raysr11Edit/Delete MessageReply w/QuoteDirect Link to This Post
Will all Fiero fuel tanks interchange? I have an '84 that needs a tank and there's an '86 tank at a local yard I could p/u if it will fit.
raysr11
Report this Post02-20-2014 02:39 PM Click Here to See the Profile for raysr11Send a Private Message to raysr11Edit/Delete MessageReply w/QuoteDirect Link to This Post
I thought I had found my answer but I don't think so. So the 4 cylinder cars had the fuel line routed to the driver's side? And what about the sending unit, will the '84 sending unit work in an '86 tank? If not is it just the mounting ring that is different or is the wiring different too?
[This message has been edited by raysr11 (edited 02-20-2014).]
Report this Post02-20-2014 04:06 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
The tank for the years 84, 85, and 86 is the same. The fuel pump is different for 4 or 6 cylinder cars. I am not sure about the rest of the sender hardware, but your 84 pump assembly will fit in an 86 tank.
raysr11
Report this Post02-20-2014 04:12 PM Click Here to See the Profile for raysr11Send a Private Message to raysr11Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you for the reply.
