  best gear set option
best gear set option by fierocarb
Started on: 02-11-2014 01:37 AM
Replies: 4 (181 views)
Last post by: carbon on 02-11-2014 12:10 PM
fierocarb
Report this Post02-11-2014 01:37 AM Click Here to See the Profile for fierocarbSend a Private Message to fierocarbEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a 88 V6 with a 5-speed right now. I am looking for more fun in the low end off the line but not super high rpm at highway speeds. What is my best option for a swap in. A fiero trans or otherwise.. I am open to all ideas.
Tom
Total ratings: 88
Report this Post02-11-2014 09:20 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
carbon
Total ratings: 133
Report this Post02-11-2014 10:39 AM Click Here to See the Profile for carbonSend a Private Message to carbonEdit/Delete MessageReply w/QuoteDirect Link to This Post
In addition to that... there is the F23 option. More work involved just getting it into the car unlike a hybrid M282 or 4 speed...
The F23 was available with quite an array of final drive ratios... unfortunately, the only one with a GM Metric bell housing is the 3.94 version from the 2000-2002 J-body cars (Cavalier and Sunfire).
It is actually fairly easy to split the case of the F23, at least, easy by comparison to the Getrag M282... but the gearing options with a bell swap are as follows:
code:
00-02 Cavalier/Sunfire - Only F23 with Metric bell housing
Final 1 2 3 4 5 R
3.94 3.58 2.02 1.35 0.98 0.69 3.31
09-10 Cobalt Xfe (RPO FY1) Ecotec
Final 1 2 3 4 5 R
3.63 3.58 2.02 1.35 0.98 0.69 3.31
03-07 Ion, 05-07 Cobalt/G5 Ecotec
Final 1 2 3 4 5 R
3.84 3.58 2.02 1.35 0.98 0.69 3.31
05-07 HHR (09-10 has 3.94 FDR) Ecotec
Final 1 2 3 4 5 R
4.17 3.58 2.02 1.35 0.98 0.69 3.31
04-07 Saturn Vue - Blech! Ecotec
Final 1 2 3 4 5 R
4.41 3.58 2.02 1.35 0.98 0.81 3.31
Total ratings: 234
Report this Post02-11-2014 11:46 AM Click Here to See the Profile for WillClick Here to Email WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tom
You can't do both without changing transmissions, but a 3.4 engine swap will give you better low end punch.
carbon
Total ratings: 133
Report this Post02-11-2014 12:10 PM Click Here to See the Profile for carbonSend a Private Message to carbonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just to get you started... This is a great tool: Moonwell's Gear Ratio Calculator
[This message has been edited by carbon (edited 02-11-2014).]
