  17x11 wheels on 86 fiero, HELP!
17x11 wheels on 86 fiero, HELP! by 86lsfierogt
Started on: 01-31-2014 04:32 PM
Replies: 36 (1455 views)
Last post by: olejoedad on 02-10-2014 05:43 PM
86lsfierogt
Report this Post01-31-2014 04:32 PM Click Here to See the Profile for 86lsfierogtSend a Private Message to 86lsfierogtEdit/Delete MessageReply w/QuoteDirect Link to This Post
So just this summer I am planning on putting some rims and painting my fiero gt. What do i need to do to make 17x9.5 and 17x11 wheels fit on my fiero, i am probably using adapters but what do i need to do to the suspension and body to make it work? Any comments would help thanks!
Neils88
Total ratings: 56
Report this Post01-31-2014 04:44 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Is this for a body kit? I'm sure someone else can give exact details (there's a chart floating around here that you can see the effects of wheel size, and offsets). I'm thinking you are going to need to look for a wide track suspension kit, and completely change the panels to either flares or some other widened panel. You'll probably end up with wheels out about 4" when you're done. Whatever you do...avoid "spacers".
You will need to tell people the offsets you are proposing.
I'll look for the chart...someone will probably post it before I find it...
Wide track kit... http://arrautmotorsports.co...pension-information/
[This message has been edited by Neils88 (edited 01-31-2014).]
Neils88
Total ratings: 56
Report this Post01-31-2014 04:49 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Neils88
Member since Aug 2013
Found it...
You might be able to get away with a small spacer, depending on your offset. I'm not a fan of spacers, but from the chart, it doesn't look as bad as I initially thought. The body panels will be the challenge. I'll let someone else comment on this, since I don't have any experience with installing flares.
Custom2M4
Total ratings: 114
Report this Post01-31-2014 06:10 PM Click Here to See the Profile for Custom2M4Send a Private Message to Custom2M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
10" wheels would be a lot easier, and has been done right with a stock fiero body. You will require coil overs in the rear though.
86lsfierogt
Report this Post02-01-2014 04:46 AM Click Here to See the Profile for 86lsfierogtSend a Private Message to 86lsfierogtEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am trying to keep it as stock as possible, i can maybe do a little flaring on the rear or so....the offset is +50...back space is 7.987 on the rear. Fromt is +56 offset
Neils88
Total ratings: 56
Report this Post02-01-2014 03:44 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
You're never going to be able to keep things stock (mechanically or appearance) with this much wheel width. Likely going to need 2" spacers (or better yet, widetrack kit/coilovers) and 3" flares. Why do you want so much width?
IMSA GT
Total ratings: 250
Report this Post02-01-2014 06:09 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
The maximum you can go is 17x10 with the proper offset.....and that is with a widebody kit or IMSA. On a stock Fiero. the rear of the wheel lip will be about 1/4" away from the strut knuckle in the rear and the front of the wheel will stick out 3" past the fender. If you go to a 19" wheel with coilovers, you can go with a 19x9.5 in the rear and tuck the entire wheel into the fender well due to the fact that the 19" wheel goes over the top of the strut knuckle. Here is Nosaints car with 19x9.5 in the rear.....on a stock body. Even at that width, he is right on the border of the wheel coming past the fender lip.
[This message has been edited by IMSA GT (edited 02-01-2014).]
Report this Post02-01-2014 07:55 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
It all depends on how much work you want to put into in. Fog shortened his lower a-arms and modified the top of the strut to fit some 325 ET street tires under his car. They didn't tuck completely under, but it was close. He ended up popping his panels out to cover them:
Build thread:
https://www.fiero.nl/forum/Forum2/HTML/104511.html
I played around with a 10 1/2" wheel and got it tucked under the stock 88 notchie panels, but its 18" and I shortened the lateral links and relocated the top of the strut inboard 1". It was just a test fit as I wanted to get my LS4/F40 swap running and didn't want to spend the $$$ on the shorter axles that were needed for this mod to work. Eventually, I will get back to it.
Rear frame rail clearance:
Strut clearance:
From the rear. This was before I moved the top of the struts in, so the wheel has some positive camber.
Lots more pictures and measurements in this thread:
https://www.fiero.nl/forum/Forum2/HTML/120740.html
Neils88
Total ratings: 56
Report this Post02-01-2014 08:02 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Strut clearance:
Strange usage of the word "clearance"...
86lsfierogt
Report this Post02-02-2014 02:22 AM Click Here to See the Profile for 86lsfierogtSend a Private Message to 86lsfierogtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry guys didn't mean it like stock stock. I would want to get that kit for the suspension and probably pop the fenders out an inch. And cause i am getting the c4 grandsport wheels that's why im going that wide..
RCR
Total ratings: 102
Report this Post02-02-2014 09:44 AM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
... And cause i am getting the c4 grandsport wheels that's why im going that wide..
You didn't mention how you will handle the bolt pattern change... What is your plan?
Bob
86lsfierogt
Report this Post02-02-2014 12:58 PM Click Here to See the Profile for 86lsfierogtSend a Private Message to 86lsfierogtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Plan on buying adapters with whatever space i need so i wont get spacers...
Custom2M4
Total ratings: 114
Report this Post02-02-2014 02:12 PM Click Here to See the Profile for Custom2M4Send a Private Message to Custom2M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Adapters are spacers, just with a different secondary bolt pattern.
86lsfierogt
Report this Post02-02-2014 05:37 PM Click Here to See the Profile for 86lsfierogtSend a Private Message to 86lsfierogtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yea thats what i ment
Total ratings: 236
Report this Post02-03-2014 11:41 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
9.5s will fit with 17's or larger on the 84-87 cars, but must be 18's or larger on the '88 cars... With the right offset, as you mentioned.
infinitewill
Total ratings: 85
Report this Post02-03-2014 07:00 PM Click Here to See the Profile for infinitewillSend a Private Message to infinitewillEdit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by infinitewill (edited 01-01-2016).]
Total ratings: 236
Report this Post02-04-2014 10:47 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sereis8217's wearing an 18x9-45 on the rear of his Formula:
http://realfierotech.com/ph...opic.php?f=7&t=17776
WCF claims 17x9-45 will fit an 84-87 car.
From my measurements, I'm pretty sure 9.5 will fit on an '88. However, before you throw money down for wheels, get a Percey's Wheel Right or similar measurement tool to measure for yourself.
[This message has been edited by Will (edited 02-04-2014).]
Report this Post02-04-2014 11:37 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
I hope you dont think that the wide wheels and tires are going to improve handling.
86lsfierogt
Report this Post02-05-2014 10:52 AM Click Here to See the Profile for 86lsfierogtSend a Private Message to 86lsfierogtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yea i know that, its just for looks I've always wanted those rims on a fiero. I'm willing to buy the wide track and flare the fenders...
Total ratings: 236
Report this Post02-05-2014 11:01 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Why wouldn't they?
fireboss
Total ratings: 58
Report this Post02-06-2014 02:53 AM Click Here to See the Profile for firebossSend a Private Message to firebossEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Will:
Why wouldn't they?
FieroBobo
Report this Post02-06-2014 10:29 PM Click Here to See the Profile for FieroBoboSend a Private Message to FieroBoboEdit/Delete MessageReply w/QuoteDirect Link to This Post
I hope you don't think that the wide wheels and tires are going to improve handling.
You are implying that wider wheels and tires will NOT improve handling. Please explain.
I was under the impression that going to wider rear tires would improve handling if you could get the front/rear tire widths to match up with the Fiero's front/rear weight distribution. Roughly 45%/55%.
Thanks,
~ Bob ~
"Its nice to be important.
Its more important to be nice."
Report this Post02-07-2014 09:04 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
There are limits to increased tire width for handling improvement. If you go too wide, the handling in real world conditions will suffer.
Zac88GT
Report this Post02-07-2014 11:16 AM Click Here to See the Profile for Zac88GTClick Here to visit Zac88GT's HomePageSend a Private Message to Zac88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tell that to my Miata!
You would have to go pretty wide before you're going to stop seeing positive effects. My miata (2300lbs) is running 15x10" wheels with 275 tires, and believe it or not the fastest guys are running even wider! Sure, there will be a point where enough is enough, but a 10" or 11" wide lightweight wheel for Fiero will see handling improvements over a 7".
Report this Post02-07-2014 11:32 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice!
Stock suspension?
KurtAKX
Total ratings: 128
Report this Post02-07-2014 11:46 AM Click Here to See the Profile for KurtAKXSend a Private Message to KurtAKXEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice!
Stock suspension?
A stock Miata rolls about that much on 195/50-15 street tires.
What I'm curious about is that camera set-up on the nose- is that two lenses?
Total ratings: 236
Report this Post02-07-2014 12:03 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
A) Not with anything that will fit under a Fiero's bodywork.
B) Define "real world handling"
Report this Post02-07-2014 12:08 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rain, rough pavement, tire wear..........
Zac88GT
Report this Post02-07-2014 12:37 PM Click Here to See the Profile for Zac88GTClick Here to visit Zac88GT's HomePageSend a Private Message to Zac88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's got Koni sports with stiffer springs, and the camera is the 3D GoPro system.
fierosound
Total ratings: 286
Report this Post02-07-2014 05:26 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can get 17x8.75" wide for $140 and you won't have to rebuild the car to make them fit under the fender.
You'll still need adapters. http://www.pinnaclecorvette..._C6_p/oe-9453148.htm
Calgary time/temp
[This message has been edited by fierosound (edited 02-07-2014).]
Joseph Upson
Total ratings: 88
Report this Post02-07-2014 06:17 PM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
245/40R18 on the rear. Rainy days scare me especially on curvy off ramps. Handling and traction is great, but the more tire surface area under the same weight the greater the chance of hydroplaning on a car already prone to wanting to swap ends on slippery wet roads.
Total ratings: 236
Report this Post02-07-2014 07:06 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rain: As long as you don't hydroplane, if the car's balanced in the dry, it's balanced in the wet. Wide tires mean easier hydroplaning. So what? Weighing less than 3000# means easier hydroplaning. Don't drive summer tires in the winter.
Rough Pavement: Nothing handles well on rough pavement
Tire Wear: Alignment settings take care of this. If you're a grandma who never drives hard in the corners, why are you reading a thread on wide wheels and tires?
If you have a rear bar, get rid of it.
I have 245's and the wet world is my playground, but it wasn't so when I had a rear bar.
Report this Post02-07-2014 08:07 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
"If you're a grandma that doesn't drive hard in the corners............."
Now thats funny!
A tip of the hat to Kurt for pointing out my blunder.........
[This message has been edited by olejoedad (edited 02-10-2014).]
KurtAKX
Total ratings: 128
Report this Post02-10-2014 12:41 PM Click Here to See the Profile for KurtAKXSend a Private Message to KurtAKXEdit/Delete MessageReply w/QuoteDirect Link to This Post
"If your a grandma that doesn't drive hard in the corners............."
Now thats funny!
The funniest part was when you could've used the "quote" function and didn't- Will used the proper (you're) and then you incorrectly paraphrased (your) in a response.
I know you're a well-respected engine swapping, Fiero-working-on guy around my neck of the woods, but out of curiosity, do you have any background with NASA, SCCA ITx or Solo, or HPDE?
[This message has been edited by KurtAKX (edited 02-10-2014).]
Report this Post02-10-2014 02:57 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Posting from a smart phone isn't all it's cracked up to be.
Jeez!
My only point was this.......you cant just bolt supersize tires and wheels on a car and expect good handling without making other changes as well.
Flame on!
Total ratings: 236
Report this Post02-10-2014 05:15 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Of course not, the car and suspension are a system and each factor affects many others.
However, any discussion of handling that doesn't begin and end with tires is wasted.
Report this Post02-10-2014 05:43 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
z
Exactly.
