  pictures of 3800 mounts in 1988 cradle ?
pictures of 3800 mounts in 1988 cradle ? by Lou6t4gto
Started on: 01-19-2014 07:27 PM
Replies: 5 (393 views)
Last post by: Darth Fiero on 02-06-2014 06:25 PM
Lou6t4gto
Report this Post01-19-2014 07:27 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
seems like the "plot"s about to change, my 2nd gen 3800SC/Auto is Now mounted in my spare '86 cradle, but now I will be putting it in a '88 ! Any pictures or opinions of what Mounts are needed? are ANY of the mounts the "same" as for the '86 setup ? I surely Hope the Harness is the same ! Thanks
revin
Total ratings: 234
Report this Post01-20-2014 08:51 AM Click Here to See the Profile for revinSend a Private Message to revinEdit/Delete MessageReply w/QuoteDirect Link to This Post
They use the same mounting position.
Harness...Not sure, who made it , so I would bet you will have to move a pin or 2 around the C500.
Lou6t4gto
Report this Post01-20-2014 12:52 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I made the Harness (per GMTUNERS charts),Please tell me the Harness is the same :-(
bomluuk
Report this Post02-04-2014 06:27 PM Click Here to See the Profile for bomluukSend a Private Message to bomluukEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm curious of the answer to this as well. Hoping it will help me with my issue (3800 motor/harness came out of an 88 into my 86).
bomluuk
Report this Post02-06-2014 05:00 PM Click Here to See the Profile for bomluukSend a Private Message to bomluukEdit/Delete MessageReply w/QuoteDirect Link to This Post
This thread alluedes to the fact that the wiring is slightly different, but does not elaborate. Any insight from anyone?
https://www.fiero.nl/forum/A...120111-2-108477.html
Darth Fiero
Total ratings: 361
Report this Post02-06-2014 06:25 PM Click Here to See the Profile for Darth FieroClick Here to visit Darth Fiero's HomePageSend a Private Message to Darth FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
The wiring harness connections at the Fiero C203 and C500 connectors shouldn't be much different from 1986 to 1988 models. There are differences if one car had an automatic and the other had a manual and if one car had a 4cyl and the other had a V6. But, for the most part, the pinouts should be the same (see below link).
http://www.gmtuners.com/fil...203_C500_pinouts.pdf
-ryan
OVERKILL IS UNDERRATED
