  Clutch Inspection Plate?
Clutch Inspection Plate? by fiero5150
Started on: 01-08-2014 11:59 PM
Replies: 3 (621 views)
Last post by: Francis T on 01-09-2014 06:45 PM
fiero5150
Report this Post01-08-2014 11:59 PM Click Here to See the Profile for fiero5150Send a Private Message to fiero5150Edit/Delete MessageReply w/QuoteDirect Link to This Post
Is there a clutch inspection plate on a stock 1988 GT V6 with a 5 speed trans? If so, where is it located? Thanks for your input.
Report this Post01-09-2014 06:45 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can only see the back side of the flywheel if you remove the dust shield between the engine and the lower bell housing, but you can't see the clutch disk. You would need to separate the transmission from the engine to see the disk.
fiero5150
Report this Post01-09-2014 03:43 PM Click Here to See the Profile for fiero5150Send a Private Message to fiero5150Edit/Delete MessageReply w/QuoteDirect Link to This Post
OK. Thanks
Francis T
Total ratings: 119
Report this Post01-09-2014 06:45 PM Click Here to See the Profile for Francis TClick Here to visit Francis T's HomePageSend a Private Message to Francis TEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's a pet peeve of mine. Like it would cost a zillion bucks to add a hole for a little tin cover when they cast bell housings? But then the auto makers don't care about servicing issues. Besides, if takes longer they can charge more.
