  !95 Fiero GT 2.8 crank, no start
!95 Fiero GT 2.8 crank, no start by rattman1
Started on: 01-05-2014 03:59 PM
Replies: 11 (828 views)
Last post by: 2.5 on 01-08-2014 08:42 AM
rattman1
Report this Post01-05-2014 03:59 PM Click Here to See the Profile for rattman1Send a Private Message to rattman1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Been working on a friends 85 Fiero with a 2.8 v-6. It has injector pulse and tach signal and spark and 45psi at the rail. I'm beating my head against a wall. I'm thinking injectors are bad. It was sitting for 5 years. Any way to possibly clean injectors?
Report this Post01-05-2014 04:21 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Welcome to the Forum!
When you get a chance, play with the SEARCH function, and you will find 110 answers to your question, but the short answer is yes, and for a car that has been sitting 5 years, the injectors are surely stuck.
https://www.fiero.nl/forum/Forum2/HTML/128674.html
rattman1
Report this Post01-05-2014 04:24 PM Click Here to See the Profile for rattman1Send a Private Message to rattman1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I searched no start but that all had to do with the pickup on the distributor. Ohh well. Thanks. I'm gonna order some new injectors. Which would you recommend as it's my first time working with fieros. I've worked on 3.4's and 3.8's but never 2.8's.
Report this Post01-05-2014 04:27 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Injectors rarely go bad.....and cleaning is not expensive..so I would recommend that you send your injectors to a cleaning service....like the one in that link.
rattman1
Report this Post01-05-2014 04:38 PM Click Here to See the Profile for rattman1Send a Private Message to rattman1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'd be looking at over 100 for cleaning and testing and + shipping. Might as well look at getting rebuilt injectors if I can find any.
86soon3.4
Report this Post01-05-2014 08:01 PM Click Here to See the Profile for 86soon3.4Send a Private Message to 86soon3.4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Does it have compression? Is timing correct? Did you check timing at TDC?
Steve
indygrandprix
Report this Post01-05-2014 08:29 PM Click Here to See the Profile for indygrandprixSend a Private Message to indygrandprixEdit/Delete MessageReply w/QuoteDirect Link to This Post
If the fuel your trying to start it with is 5 year old fuel that could be an issue
Fiero_Mark
Report this Post01-07-2014 03:34 AM Click Here to See the Profile for Fiero_MarkSend a Private Message to Fiero_MarkEdit/Delete MessageReply w/QuoteDirect Link to This Post
You may NOT have spark , even though you think that you do. Read my post within this thread and the results:
https://www.fiero.nl/forum/Forum2/HTML/130806.html
You may be able to fix your problem for just 15 minutes of your time if you have a KNOWN good replacement coil handy, or maybe just 15 minutes + $30 for a new coil. Much better than the 30 days + $300+ I spent before figuring this out, or your $100 + $?? + $??.
Check it out and get back to us. Best of luck, hope it works (again).
- Mark
[This message has been edited by Fiero_Mark (edited 01-07-2014).]
Total ratings: 291
Report this Post01-07-2014 03:56 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Soaking the tips in injector cleaner will free them. You can activate them with a 9V battery. You should hear them click. You should be able to blow through them, slightly when activated. Don't leave power to the injectors for an extended period, you will burn out your injectors.
f85gtron
Report this Post01-07-2014 07:13 AM Click Here to See the Profile for f85gtronSend a Private Message to f85gtronEdit/Delete MessageReply w/QuoteDirect Link to This Post
givin your two choices, throw some starter fluid on it... if it starts, injectors......if it doesn't, then ignition.
Ron
uhlanstan
Total ratings: 427
Report this Post01-07-2014 07:58 PM Click Here to See the Profile for uhlanstanSend a Private Message to uhlanstanEdit/Delete MessageReply w/QuoteDirect Link to This Post
f85 is correct
there are 2 main trouble shooting technique
with strong battery
1=hook a spark plug gaped to .060 up to one of the distributor spark plug wires lay it on ground firmly,also run wire to block & spark plug
now if you have good hot red spark ! not weak tit yellow spark
2 = remove air cleaner snorkle, squirt fresh gas or starting fluid into TBI & attemp to start
have blanket or some method to stop possible fire
corrosion is a major factor in no start of a car that sits for years, the connector between the coil & distributor often have corrossion
if you know for certain a car was running when it was stopped normally the coil .pick up coil,module are O.K. the dist cap & rotor may be corroded
Report this Post01-08-2014 08:42 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ron
I'd do that too.
