  clutch fork interchangeability?
clutch fork interchangeability? by timinator
Started on: 12-27-2013 03:21 PM
Replies: 3 (147 views)
Last post by: stickpony on 12-31-2013 07:42 PM
timinator
Report this Post12-27-2013 03:21 PM Click Here to See the Profile for timinatorSend a Private Message to timinatorEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi. I was wondering if anyone knows if one can swap a (cheaper) 4 cylinder fork into a '87 getrag tranny by changing bushings and/or enlarging the shaft holes, etc? Or could share the diameter of different fiero fork shafts.
trotterlg
Report this Post12-27-2013 04:35 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't think the transmissions had different forks depending on the engine. Larry
rogergarrison
Total ratings: 551
Report this Post12-27-2013 04:47 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
All I know is mid 86 they changed from a welded together piece of junk to a one piece. It takes a different pin. I bought it as a kit when I replaced a clutch. Mine was a 4 speed, dont know if 5 speed used the same setup.
stickpony
Report this Post12-31-2013 07:42 PM Click Here to See the Profile for stickponyClick Here to visit stickpony's HomePageSend a Private Message to stickponyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey Roger, do you have a gm part number for that one-peice clutch fork for the 4 speed M17 Muncie? my clutch fork just cracked, and it is the welded together crappy one.
