  axle boot replaceement
axle boot replaceement by garage monster
Started on: 12-16-2013 08:26 PM
Replies: 4 (473 views)
Last post by: cmechmann on 12-17-2013 12:55 PM
garage monster
Report this Post12-16-2013 08:26 PM Click Here to See the Profile for garage monsterSend a Private Message to garage monsterEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have my V8 out to do some work. The passenger side axle over extended and the tripot separated and punctured the axle boot. The axle is almost new. Where can I get a replacement boot and how does the axle come apart to put the boot back on?
Custom2M4
Total ratings: 114
Report this Post12-16-2013 08:41 PM Click Here to See the Profile for Custom2M4Send a Private Message to Custom2M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
A one piece boot gets stretched over the cv with a stretcher tool. They are available at any autoparts store ( the boot)
garage monster
Report this Post12-17-2013 01:55 AM Click Here to See the Profile for garage monsterSend a Private Message to garage monsterEdit/Delete MessageReply w/QuoteDirect Link to This Post
I will check that out. Seems impossible the small end that fits the axle could stretch over the CV joint.
Thanks for the tip.
Zeak
Report this Post12-17-2013 08:14 AM Click Here to See the Profile for ZeakSend a Private Message to ZeakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Try this video. A good repair manual will also have a good step by step on how to fix it.
http://www.youtube.com/watch?v=-S-ofMoWsr0
[This message has been edited by Zeak (edited 12-17-2013).]
cmechmann
Report this Post12-17-2013 12:55 PM Click Here to See the Profile for cmechmannSend a Private Message to cmechmannEdit/Delete MessageReply w/QuoteDirect Link to This Post
The video has very good instructions.
The only thing that I would add. When doing the tripot end, wipe off as much grease as possible, leave the bearing assemblies on the tripot. Use (duct)tap or very wide rubber band to keep the assembly together. Some of the assemblies are the round type and reinstalling the needle bearing can be a pain.
After you reinstall the assembly onto the axle, remove the tap, clean with Braklean. You have to insure you clean out the old grease. The new grease may not be compatible. Even if clean, it can cause the new grease to break down. Push some of the grease into the needle bearings. Take about half the grease and put it in the housing. The rest, put in the boot right before you put the clamp on.
