  EGR: does it, or will it hurt the motor to deleat the tube
EGR: does it, or will it hurt the motor to deleat the tube by georgie
Started on: 12-09-2013 07:51 PM
Replies: 7 (604 views)
Last post by: georgie on 12-11-2013 12:05 PM
georgie
Report this Post12-09-2013 07:51 PM Click Here to See the Profile for georgieSend a Private Message to georgieEdit/Delete MessageReply w/QuoteDirect Link to This Post
My EGR tube is bad. What is the truth about blocking it off ? Iv heard its not good for the motor, an at the same time I heard it's ok an does no harm..
Report this Post12-09-2013 08:11 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Try the SEARCH function and click the 'entire form + archives' dropdown to get all you could ever want to ask about the EGR system.
georgie
Report this Post12-09-2013 08:43 PM Click Here to See the Profile for georgieSend a Private Message to georgieEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm going to keep it stock, no mickey mouse!!! Get a new tube like a smart person. Thx
Report this Post12-09-2013 09:28 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Bless you, fellow Earthling.
rogergarrison
Total ratings: 551
Report this Post12-10-2013 11:53 AM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think Rodney makes a stainless steel flexible replacement. Much better than the stock one and wont crack from heat and flexing.
lou_dias
Report this Post12-10-2013 04:03 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can block it off and get a chip reprogrammed to not use it from someone in the mall.
It does NO harm disabling it.
[This message has been edited by lou_dias (edited 12-10-2013).]
Total ratings: 463
Report this Post12-11-2013 08:31 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you're going to block it off (which won't really get you any performance gain and will use a touch more gas, as stated) be sure to get a reprogrammed chip.
DON'T just fake out the system. If you fake out the system, you will run too much spark advance and too lean fuel mixture.
THAT is what hurts the motor (and also what helps the fuel mileage when it's working properly.)
Praise the Lowered!
georgie
Report this Post12-11-2013 12:05 PM Click Here to See the Profile for georgieSend a Private Message to georgieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank's every one for all the info. I'm going to replace the tube with a new one from rodney's.
