  Starting Problem
Starting Problem by dallasreese
Started on: 12-08-2013 10:49 AM
Replies: 8 (227 views)
Last post by: theogre on 12-13-2013 01:33 AM
dallasreese
Report this Post12-08-2013 10:49 AM Click Here to See the Profile for dallasreeseSend a Private Message to dallasreeseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello Again Guys....I have 84 Fiero that will not start with ignition switch but will by jumping at solenoid...I get dash lights come on with switch but no turn over. I do hear clicking at engine compartment when I turn the key and also have new ignition switch install think that was the problem..
84fiero123
Total ratings: 325
Report this Post12-08-2013 11:09 AM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Are talking about the switch the key goes in or the electric switch on the bottom of the column that has the electrical plugs in it?
the key one I don't think could be the problem, but the one the electrics plug in could be, do you feel the spring when you turn it to start? if not you may have it in the wrong position or a new defective switch, both are possible.
Steve
newfiejeff
Report this Post12-08-2013 11:16 AM Click Here to See the Profile for newfiejeffSend a Private Message to newfiejeffEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just clicking in the engine compartment? Did you try boosting the car to see if it works, usually when a battery is almost dead you will hear clicking. Could be a bad connection at the starter. I would try boosting it first and go from there.
Let us know.
seajai
Total ratings: 52
Report this Post12-08-2013 12:39 PM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check for power into and out of the gear selector switch on the transmission (auto) or clutch switch by the pedal (manual) with the key held in the "start" position. Don't have an 84 service manual so I'm not sure of the wire colors. The 86 wire colors are: Yellow wire is power from the ign switch and purple goes to the starter.
dallasreese
Report this Post12-08-2013 02:10 PM Click Here to See the Profile for dallasreeseSend a Private Message to dallasreeseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi guys...I have to be gone for a few hours but to give you this...I know the battery is good....The ignition switch is new..(not the key mechanism)....and I do have spring action on the ignition switch...I had to install new solenoid a few months ago and may not have got good connection there but it was doing this prior to this install...I hooked up a toggle switch from solenoid and sometime this toggle works and sometimrs it doesnt...seems to not work when engine gets driven far distance as if heating.causes...but can crank with screwdriver straight at solenoid...thx...
fierocarparts
Report this Post12-10-2013 09:13 AM Click Here to See the Profile for fierocarpartsSend a Private Message to fierocarpartsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does it crank fine when cold?
I had a BBC that would get heat soaked. Replaced starter and solenoid numerous times. Finally installed shield and never had another problem.
dallasreese
Report this Post12-10-2013 10:13 AM Click Here to See the Profile for dallasreeseSend a Private Message to dallasreeseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes...cranks fine when cold..What is BBC?
dallasreese
Report this Post12-12-2013 08:49 PM Click Here to See the Profile for dallasreeseSend a Private Message to dallasreeseEdit/Delete MessageReply w/QuoteDirect Link to This Post
@ Seajai....I have wiring diagam and it is Yellow wire going into the shift switch and purple coming out..
My question is...Where exactly is this switch with wires coming into and out..so I can test?
Thx...
Report this Post12-13-2013 01:33 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Above diagram Does Not apply to 84.
See my Cave, Alternator Sense for alt and starter wiring.
Check ignition switch adjustment and link between switch and lock.
man trans check clutch switch
auto trans check neutral safety switch
[This message has been edited by theogre (edited 12-13-2013).]
