  selector cable can be adjusted right?
selector cable can be adjusted right? by LoW_KeY
Started on: 11-19-2013 01:08 AM
Replies: 4 (205 views)
Last post by: Imnuts on 03-17-2014 01:25 PM
LoW_KeY
Total ratings: 150
Report this Post11-19-2013 01:08 AM Click Here to See the Profile for LoW_KeYSend a Private Message to LoW_KeYEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok lately seems like 5th is becoming a royal PITA to hit. I'm hitting 3rd instead not unless I use both hands to shift
Just wanted to double check this.. been awhile and I'm feeling a bit car stupid
http://www.gofundme.com/diabetescasey
3800 SC/IC Formula whines more than your girl... 12.7@113
08 Cobalt SS TC - ZZP tuned, K&N SRI, 6k HID's 13.31@107
Bloozberry
Total ratings: 311
Report this Post11-19-2013 07:37 AM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here are some instructions to adjust the cables at the transmission end: www.fiero.nl/forum/Archives...120111-2-108049.html
fierosound
Total ratings: 287
Report this Post11-19-2013 08:54 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
And if that doesn't work, the shifter mechanism itself may be cracked or have broken welds.
After having all kinds of shifting issues that new cables, adjusting etc. didn't fix, I found that my GT's shifter was cracked and needed a weld repair.
Calgary time/temp
LoW_KeY
Total ratings: 150
Report this Post11-19-2013 09:47 AM Click Here to See the Profile for LoW_KeYSend a Private Message to LoW_KeYEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks guys know the driving season almost over but till snow hits I'm still going
Imnuts
Report this Post03-17-2014 01:25 PM Click Here to See the Profile for ImnutsSend a Private Message to ImnutsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Update on possible selector cable problem: I was having a hard time pushing shifter over to 5th and reverse. After working on the problem for a bit I noticed the rubber boot on my aftermarket cable had slid up on off the non moving shaft on to the cable. Every time it tried to go over to 5th or reverse the boot would compress and restricted the movement of the shifter. I pulled it back down where it belonged and zip tied it and things where back to normal. Hear is a picture of how it should look except I don't have it hooked back to the trans yet.
