  How Does The Front Upper Balljoint Boot Attach Please and Thank You - 1986 2.8
How Does The Front Upper Balljoint Boot Attach Please and Thank You - 1986 2.8 by PK
Started on: 10-26-2013 07:37 AM
Replies: 2 (138 views)
Last post by: PK on 10-26-2013 10:00 AM
PK
Report this Post10-26-2013 07:37 AM Click Here to See the Profile for PKSend a Private Message to PKEdit/Delete MessageReply w/QuoteDirect Link to This Post
Greetings PFF'ers,
I am in the process of replacing a torn RHS Upper front ball joint boot. The balljoint is a Moog brand adjustable. I could not find a snap ring or oubt in the balljoint housing so pulled the boot off. Is there some form of retainer for these balljoints that I have missed? It was reasonably difficult to hoike out and has a thicker (than the rest of the boot) rubber lip that sits inside the balljoint housing.
My bag o bits has a different sized boot with the same thick lip and some less manly boots that might do the job with a poly boot over the top. But would like to know if I have missed a snap ring or other retaining system afore I decide on my next move.
Cheers
PK
Bloozberry
Total ratings: 311
Report this Post10-26-2013 08:06 AM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
None of the aftermarket ball joints I've ever installed came with a snap ring. Once the stud is fed through the hole in the knuckle, the boot simply gets compressed around the base of the ball joint. It's not ideal.
PK
Report this Post10-26-2013 10:00 AM Click Here to See the Profile for PKSend a Private Message to PKEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you Blooze for the info and for the fast response. Having mocked it up with the bag'0'bits boots I am reasonably happy as the first boot goes inside the housing as did the orig (albeit with less holding it in place) and the poly boot squishes over the outside as its compressed.
Cheers
PK
