  Door Ajar light stays on
Door Ajar light stays on by kevin
Started on: 10-19-2013 01:58 PM
Replies: 7 (911 views)
Last post by: PatrickTRoof on 10-21-2013 03:30 PM
kevin
Report this Post10-19-2013 01:58 PM Click Here to See the Profile for kevinSend a Private Message to kevinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fellas,
My driver door plunger, that activates the Door Ajar light on the dash, it will not blink off when I shut the driver door? Do I simply replace that plunger? If so, who sells them?
Cordially,
kevin
seajai
Total ratings: 51
Report this Post10-19-2013 02:14 PM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
What year is you car? The ajar indicator will illuminate with either door, hood, or trunk lid open. Everything needs to be shut to make the light go off. If the light is on with everything closed, you will need to unplug the switches, one at a time, until the light goes out to figure out which one is bad.
[This message has been edited by seajai (edited 10-19-2013).]
PatrickTRoof
Report this Post10-19-2013 10:19 PM Click Here to See the Profile for PatrickTRoofSend a Private Message to PatrickTRoofEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had that problem. the ajar light would randomly blink when it wanted to. I fixed it by removing the bulb from the instrument panel.
Neils88
Total ratings: 55
Report this Post10-19-2013 11:09 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
That works with the Check Engine Light too...
VikingRedBaron
Report this Post10-20-2013 12:16 AM Click Here to See the Profile for VikingRedBaronSend a Private Message to VikingRedBaronEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mine stayed on on my 87 GT as well.
It was the front hood. Switch was to short to reach the hood.
I was too lazy to adjust it, so I put a low side R12 A/C fitting cap on it.
Been that way over 2 years now.
Problem solved
[This message has been edited by VikingRedBaron (edited 10-20-2013).]
ZombiePenguin
Report this Post10-20-2013 08:52 PM Click Here to See the Profile for ZombiePenguinSend a Private Message to ZombiePenguinEdit/Delete MessageReply w/QuoteDirect Link to This Post
my passenger side door did the same thing, i just built up some electrical tape until it would turn off the light
da.slyboy
Report this Post10-21-2013 12:07 PM Click Here to See the Profile for da.slyboySend a Private Message to da.slyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I second checking the front hood switch. Mine was also too short to activate it(not sure why). But I added a quarter size piece of rubber to the hood to push it down more and it works just fine now.
PatrickTRoof
Report this Post10-21-2013 03:30 PM Click Here to See the Profile for PatrickTRoofSend a Private Message to PatrickTRoofEdit/Delete MessageReply w/QuoteDirect Link to This Post
