  Need power for Fog lights
Need power for Fog lights by stefanosg
Started on: 10-12-2013 01:46 PM
Replies: 3 (130 views)
Last post by: Dodgerunner on 10-12-2013 03:31 PM
stefanosg
Report this Post10-12-2013 01:46 PM Click Here to See the Profile for stefanosgClick Here to visit stefanosg's HomePageSend a Private Message to stefanosgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is there a good spot to tap(up front) for power to the driving/fog lights or should I just run a long wire to the battery?
trotterlg
Report this Post10-12-2013 02:53 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
You should probalby run a wire from the battery using a relay to switch it on. You could power the relay from the tail lights if you want to switch them on when the lights are on. That way you only have power on the long wire run when you turn on the lights. Larry
stefanosg
Report this Post10-12-2013 03:17 PM Click Here to See the Profile for stefanosgClick Here to visit stefanosg's HomePageSend a Private Message to stefanosgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds good, Thanks
Dodgerunner
Total ratings: 323
Report this Post10-12-2013 03:31 PM Click Here to See the Profile for DodgerunnerClick Here to visit Dodgerunner's HomePageSend a Private Message to DodgerunnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Instead of trying to tie into the tail lights use the trunk light socket by the heater/ac fan to control your relay. Easy to get to and it turns on with the tail lights.
I use it to drive my LED driving lights since they don't use much power.
Unless you want to mount the relay back by the engine. Then the tail lights are as good as any.
Be sure and fuse the line from the battery for safety.
[This message has been edited by Dodgerunner (edited 10-12-2013).]
