  Quick start-Slow start
Quick start-Slow start by NiotaFiero
Started on: 10-08-2013 07:07 AM
Replies: 4 (129 views)
Last post by: theogre on 10-08-2013 11:54 AM
NiotaFiero
Report this Post10-08-2013 07:07 AM Click Here to See the Profile for NiotaFieroSend a Private Message to NiotaFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
87 GT 2.8__When I go to start the car in the morning it starts before the engine turns over twice, which is great but after I driver it and it has time to warm up it takes several seconds to start and then blows a big puff of blue smoke when it starts. Any suggestions ?
Report this Post10-08-2013 10:41 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Many 2.8s have leaky valve guide seals. The result is a puff of smoke when you start it up.
Your cold start injector is working well. When the engine is warm it will not work and it will take longer to start the car.
https://www.fiero.nl/forum/A...090907-2-089685.html
[This message has been edited by Gall757 (edited 10-08-2013).]
trotterlg
Report this Post10-08-2013 11:30 AM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Also could be that the cold start injector is leaking and allowing fuel to blead into the engine after shutdown basically flooding it. When you try to start it hot it's flooded and then blows a bunch of smoke until it burns out all the raw gas. Larry
Report this Post10-08-2013 11:50 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cold start is coolant temp dependent and ONLY when starter is on.
Switch Close when coolant temp below ~95°F.
Coolant is warmer then On time goes down, max time is 8 second at 20°F coolant temp.
Per 87SM
Report this Post10-08-2013 11:54 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Mar 99
Likely black to drk gry smoke...
Blue usually mean burning oil.
