  Spec stage 5 clutch.... too radical?
Spec stage 5 clutch.... too radical? by MaxCubes
Started on: 10-08-2013 02:06 AM
Replies: 9 (717 views)
Last post by: fierosound on 10-10-2013 07:56 AM
MaxCubes
Report this Post10-08-2013 02:06 AM Click Here to See the Profile for MaxCubesSend a Private Message to MaxCubesEdit/Delete MessageReply w/QuoteDirect Link to This Post
I wanna get some feedback before I purchase a stage 5 clutch for my supercharged 4.9
Having problems with my current spec stage 3 slipping..... my engine makes a ton of low end torque
..... what are the advantages and disadvantages of Stage 5
Arns85GT
Total ratings: 202
Report this Post10-08-2013 01:02 PM Click Here to See the Profile for Arns85GTSend a Private Message to Arns85GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just picked up the Spec II + which is rated to 417 ftlbs for my 4.9 NA
Spec told me that the + is the kevlar faced disk which is smoother for the street.
The Spec 5 comes with that kevlar faced disk, I think, so if it does, it will behave on the street.
Your supercharged 4.9 can probably benefit from it
Hope this helps
Arn
daniel87fierogt
Total ratings: 52
Report this Post10-08-2013 04:47 PM Click Here to See the Profile for daniel87fierogtSend a Private Message to daniel87fierogtEdit/Delete MessageReply w/QuoteDirect Link to This Post
The spec stage 5 is the sindered iron disc. The disc is a un sprung hub so between the solid hub disc and the very aggressive material you will probably get quite a bit of chatter on engagement. You would probably would be fine with the Spec stage 4+ and it would be a lot more forgiving.
Report this Post10-08-2013 06:52 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Justinbart is the only one I know who has ran the stage 5 clutch.
The Stage 3 and Stage 4 clutches use the same friction material, but the Stage 3 is a spring hub and Stage 4 is a solid hub.
A Stage 4 is a Stage 3 (6 puck) w/o the hub springs
A Stage 4+ is a Stage 3+ (solid ring friction material) w/o the hub springs.
My LS4/F40 Fiero is daily driven with a Stage 4+ and it has very good street manners.
You might check with Spec on the pressure plate that came with your kit. They have a couple of options for higher clamp load pressure plates that will increase the holding power, at the expense of the pedal being harder to push.
hnthomps
Total ratings: 50
Report this Post10-08-2013 07:42 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a sintered iron clutch disk from another manufacturer (McLeod) and it is very grabby. It is mostly engaged fully or disengaged so it is a bit hard to be really smooth with some shifts. BTW, my car is about 300 ft lbs of torque at the wheels (3800 SC Series III with intercooler, VS cam, N* TV, and a 3.4 pulley).
Nelson
[This message has been edited by hnthomps (edited 10-09-2013).]
MaxCubes
Report this Post10-09-2013 12:45 AM Click Here to See the Profile for MaxCubesSend a Private Message to MaxCubesEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow.... looking at some specs on the Spec stage 3 versus stage 3+
The clutch I got (stage 3)... is rated at 450 ft lbs.
The stage 3 plus is rated at 580 ft lbs..... a whopping 130 pounds more than the regular stage 3
....I shoulda, coulda got the stage 3 PLUS!!!
Im wondering if the stage 3 plus will be good enough.... The stage 5 is the same price
I don't want to do anymore clutch changes!!!!!!
MaxCubes
Report this Post10-09-2013 12:53 AM Click Here to See the Profile for MaxCubesSend a Private Message to MaxCubesEdit/Delete MessageReply w/QuoteDirect Link to This Post
MaxCubes
Member since Aug 2004
I aint using that 6 puck crap no more... looks cool, but don't grab worth a damn!
Arns85GT
Total ratings: 202
Report this Post10-09-2013 09:07 AM Click Here to See the Profile for Arns85GTSend a Private Message to Arns85GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for correcting my misinformation on the 5. I was on vacation at the time I posted and I shouldn't have gone on memory on that post.
I also had a sintered iron clutch from Bullyclutch (Ottawa Clutch) and it wasn't chattery but I was only running 160 hp on it and it could well chatter with a heavy load.
Arn
zkhennings
Report this Post10-10-2013 12:15 AM Click Here to See the Profile for zkhenningsSend a Private Message to zkhenningsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would go Spec 4+, I would say 3+ but I have seen multiple accounts of high power basically destroying the spring area of the clutch, but the 4+ with solid disk should not have that problem. I have driven a car with a straight racing clutch and it is pretty much an on off switch, exactly how I would imagine the stage 5 to be, very easy to stall... So if you commute with any stop and go I would vote stage 4+
fierosound
Total ratings: 286
Report this Post10-10-2013 07:56 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
I installed a www.BullyClutch.com Stage 3 in my GT last spring. Light pedal effort and holds great!
My Spec Stage 2 worked pretty good, but the release bearing collapsed - prompting the replacement.
Calgary time/temp
[This message has been edited by fierosound (edited 10-10-2013).]
