  Is This a Front Outer Tie Rod or Did They Give Me a Rear One? **URGENT**
Is This a Front Outer Tie Rod or Did They Give Me a Rear One? **URGENT** by Big Paul
Started on: 10-05-2013 11:41 PM
Replies: 6 (436 views)
Last post by: jon m on 10-06-2013 12:28 PM
Big Paul
Report this Post10-05-2013 11:41 PM Click Here to See the Profile for Big PaulSend a Private Message to Big PaulEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey guys, I'm swapping out my front inner tie rods with Rodney's and I couldn't get the outer tie rod off of the old one. It was rusted together. So I ran to Autozone and got two new outer tie rods. They are shorter, but they thread onto the inner tie rod just fine. They don't look like they have as much of a bend in them either. Is this just because they are cheap? I am worried that I'm not able to thread far enough into them for it to be safe. I drive somewhat aggressively on occasion and I autocross as well.
The numbers on the box are
DW-ES2500RL
MOOG-ES2500RL
OE Brand-S-ES2255
TRW-ES2255R
I've googled them, but I've come up with mixed results. Any help is appreciated! My car is a 1986 GT with a 2.8.
This is somewhat urgent because I was planning to finish up my car tonight so that I could get an alignment and new tires and drive it back to my school 2 hours away tomorrow. But I want to do this correctly so that I am not jeopardising mine, or anyone elses lives by my tie rod failing while I'm driving.
Thanks!
Paul
This is with the tie rod threaded down to roughly where the alignment should be. Shows how much thread would be inside the outer tie rod. Is that enough?
This shows how much shorter the tie rod is. And also how it doesn't have the same little bend. The new one has a different dust boot thing on it as well
DaytonTD
Report this Post10-06-2013 12:18 AM Click Here to See the Profile for DaytonTDSend a Private Message to DaytonTDEdit/Delete MessageReply w/QuoteDirect Link to This Post
Personally I think it is fine, it's just slightly different over the original which is normal with some aftermarket parts, but I don't think it is anything to be concerned about. However I would wait for someone more experienced than myself to chime in if you are really concerned about the safety of less threads.
Big Paul
Report this Post10-06-2013 12:29 AM Click Here to See the Profile for Big PaulSend a Private Message to Big PaulEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's what my first thought was, but I want to be sure before I drive two hours on it at highway speed. The outer tie rod was around $25 which seems really cheap for a front tie rod. I'm afraid the parts guy didn't catch that it was a rear one. I don't want to rush it and end up causing more damage than before. A tie rod failure while driving is one of my biggest fears.
But maybe I'm just being paranoid and everything is fine...
Fierostarvin
Report this Post10-06-2013 07:04 AM Click Here to See the Profile for FierostarvinSend a Private Message to FierostarvinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can you just Google the part number on the box and see what it tells you?
Blacktree
Total ratings: 350
Report this Post10-06-2013 09:32 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
That doesn't leave much thread to hold the tie rod together. I wouldn't trust it, especially on a car that gets driven hard.
Personally, I would bite the bullet and order Rodney's tie rod ends.
Big Paul
Report this Post10-06-2013 11:59 AM Click Here to See the Profile for Big PaulSend a Private Message to Big PaulEdit/Delete MessageReply w/QuoteDirect Link to This Post
The store opened up and I gave them a call. Turns out they gave me rear tie rods instead of front tie rods. That's pretty annoying, It could have turned out really bad if I tried to instal and drive on them.
jon m
Report this Post10-06-2013 12:28 PM Click Here to See the Profile for jon mSend a Private Message to jon mEdit/Delete MessageReply w/QuoteDirect Link to This Post
Glad you got sorted.
when I am at work and about to start a job we have to go through a last minute risk assesment and 1 of the things that I always write down is: ANY DOUBTS - STOP AND RE ASSESS.
which is what you did - I understand it is a bit annoying delay wise - but better than being hospitalised.
jon
