  What is used ?
What is used ? by Lou6t4gto
Started on: 10-01-2013 11:14 AM
Replies: 1 (165 views)
Last post by: sco77 on 10-01-2013 05:53 PM
Lou6t4gto
Report this Post10-01-2013 11:14 AM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
for the 3800SC swap. when making the" thermostat Housing" using a fiero (top part of the housing) -WHAT is used for the LOWER part ?( that the fiero part gets welded to ??) the 3800 is aluminum, obviously a steel or tin lower portion is needed, but from What ? Link ? Thanks
sco77
Report this Post10-01-2013 05:53 PM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
You use the entire thing..
What I did:
Cut the tstat with cut off wheel, cutting off the part I wasn't using in my setup (the heater hose connections):
Then let it sit on a sanding wheel to machine the surfaces level, welded it in my desired angle:
The holes on the flanges don't line up, you have to VERY lightly ream the holes towards the center, doing a little bit at a time until it works. Bolt it down with 3800 gasket (+ sealant) and use socket cap bolts.
[This message has been edited by sco77 (edited 10-01-2013).]
