  FYI: Part numbers for 3800SC belts, using WCF lower alt. mount and idler pulley kit
FYI: Part numbers for 3800SC belts, using WCF lower alt. mount and idler pulley kit by Curtisk1060
Started on: 09-16-2013 08:55 PM
Replies: 1 (214 views)
Last post by: sco77 on 09-17-2013 08:21 PM
Curtisk1060
Report this Post09-16-2013 08:55 PM Click Here to See the Profile for Curtisk1060Send a Private Message to Curtisk1060Edit/Delete MessageReply w/QuoteDirect Link to This Post
I wanted top pass on some useful information for those of you yet to be replacing your assembly drive ( A/C and alternator) belt and also the supercharger belt during a 3800SC swap. I bought the lower alternator re-mount and pulley kit from West Coast Fiero so these parts relate to this combination. I bought mine at advance auto parts. My 3800SC engine is from a 2000 GTP.
The assembly drive belt is shorter than stock with this alternator mount configuration and is Dayco number 5060870, 6PK2210. The supercharger belt is a stock replacement and is Dayco number 5060665, 6PK1690. I hope this helps someone else out when searching for parts as I have learned so much from many of Pennocks' members. Just wanted tp pass on some information .. Curtis
sco77
Report this Post09-17-2013 08:21 PM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
And for those that like Gates and Gatorback better... Those part numbers would be Gates k060870 / Gatorback 4060870 and Gates k060663 / Gatorback 4060663 (663 stock pulley, 660 3.5-3.6, 658 3.2-3.5)
86 Fiero GT 4spd - L67 swap: VS cam, GenV Build Progress
98 GTP - Some mods
