  Koni struts and shocks - 88
Koni struts and shocks - 88 by DonP
Started on: 09-16-2013 05:08 PM
Replies: 5 (883 views)
Last post by: Steven Snyder on 09-18-2013 03:19 PM
DonP
Report this Post09-16-2013 05:08 PM Click Here to See the Profile for DonPClick Here to visit DonP's HomePageSend a Private Message to DonPEdit/Delete MessageReply w/QuoteDirect Link to This Post
What versions of the Konis are available for the '88? Were yellows made, or are the Reds the only choice. This is for use on a track day only car, so yellows may be appropriate if they are/were every made as an option.
Report this Post09-16-2013 05:51 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Reds were the only ones made for the 88 and the fronts are discontinued.
WCF has a lower a-arm conversion bracket that allows use of Yellow front shocks from another application.
http://www.westcoastfiero.c...spension/shocks.html
DonP
Report this Post09-16-2013 11:34 PM Click Here to See the Profile for DonPClick Here to visit DonP's HomePageSend a Private Message to DonPEdit/Delete MessageReply w/QuoteDirect Link to This Post
The WCF application looks interesting. But I've already replaced the upper and lower control arms with fabricated arms. I do not find anything but the red rear struts, which will be converted to coilovers. Thanks for the tip.
qwikgta
Total ratings: 84
Report this Post09-17-2013 02:08 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm running the Red Koni's, converted to coilover by HT Motorsports (ArrautMS now). I have them set to position 12 (all the way hard) and I love the ride. Much better then the KYB's I was running.
Rob
Amida
Total ratings: 63
Report this Post09-18-2013 02:46 PM Click Here to See the Profile for AmidaSend a Private Message to AmidaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was told by a Koni distributor that the Red front shocks are not discontinued, but will produce if a wholesaler will order 30 units or more.
Steven Snyder
Total ratings: 106
Report this Post09-18-2013 03:19 PM Click Here to See the Profile for Steven SnyderClick Here to visit Steven Snyder's HomePageSend a Private Message to Steven SnyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Only Koni "reds" were available for the Fiero. Koni yellows are the same internally as Koni reds except the valving.
If you are running anything but stock spring rates you'll want them revalved anyway. Just fine someone's used Konis which will invariably be leaking oil (they don't seem to last long...), get a good deal on them, then send them to Koni for a rebuild and at the same time have them revalved to match your target spring rates.
