  A/c belt
A/c belt by Fiero_Fastback_Freak
Started on: 09-16-2013 03:18 PM
Replies: 4 (125 views)
Last post by: jimbolaya on 09-16-2013 07:02 PM
Report this Post09-16-2013 03:18 PM Click Here to See the Profile for Fiero_Fastback_FreakClick Here to visit Fiero_Fastback_Freak's HomePageSend a Private Message to Fiero_Fastback_FreakEdit/Delete MessageReply w/QuoteDirect Link to This Post
How hard is it to change a a/c belt on a 2.8 87 gt, and what is the easiest way of doing it?
jimbolaya
Total ratings: 114
Report this Post09-16-2013 05:54 PM Click Here to See the Profile for jimbolayaSend a Private Message to jimbolayaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have an 86 and I'm assuming its the same, but not positive. It's not too hard. You'll have to remove the drive belt first, as the AC belt is behind the drive belt. Loosen the tension on the alternator, then remove drive belt. Then release the tension on the AC compressor, and pop off the AC belt. Put them back on in reverse order. Getting the tension right, and tightening the bolt is the toughest part, but all in all, not a bad job.
Jim
Report this Post09-16-2013 06:02 PM Click Here to See the Profile for Fiero_Fastback_FreakClick Here to visit Fiero_Fastback_Freak's HomePageSend a Private Message to Fiero_Fastback_FreakEdit/Delete MessageReply w/QuoteDirect Link to This Post
thanks jim
jimbolaya
Total ratings: 114
Report this Post09-16-2013 06:57 PM Click Here to See the Profile for jimbolayaSend a Private Message to jimbolayaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I forgot to mention, that I jack the car and do all of this from underneath. You will not be able to do it from up top.
Jim
jimbolaya
Total ratings: 114
Report this Post09-16-2013 07:02 PM Click Here to See the Profile for jimbolayaSend a Private Message to jimbolayaEdit/Delete MessageReply w/QuoteDirect Link to This Post
jimbolaya
Member since Feb 2007
Sorry double post.
Jim
[This message has been edited by jimbolaya (edited 09-16-2013).]
