  carburated 4.9..can I turbo charge it?
carburated 4.9..can I turbo charge it? by northstar
Started on: 09-09-2013 09:55 PM
Replies: 7 (361 views)
Last post by: northstar on 09-10-2013 09:58 PM
northstar
Report this Post09-09-2013 09:55 PM Click Here to See the Profile for northstarSend a Private Message to northstarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is this something that can be done fairly easily? What would I need to do this.what kind of hp could I expect ? Thanks
Reallybig
Report this Post09-10-2013 02:09 AM Click Here to See the Profile for ReallybigSend a Private Message to ReallybigEdit/Delete MessageReply w/QuoteDirect Link to This Post
You could probably expect a blown head gasket and the nightmares that will ensue. From all my research on the 4.9 here on Pennocks, the overwhelming info points to the 4.9 as an engine that is happiest in stock form and engineered to it's build limits. Some have been successful with adapting turbo's or blowers...time will tell. But the painfull stories I've read of failed mods to the 4.9 keep me from trying any. Ok, I'd consider the allante intake. Besides I'm happy with it the way it is! Don't let me stop you though, just use the search function.
Good luck!
Arns85GT
Total ratings: 202
Report this Post09-10-2013 05:27 PM Click Here to See the Profile for Arns85GTSend a Private Message to Arns85GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
You haven't heard of HER86GT? Turbo'd 4.9 running 11+ seconds on the quarter mile?
The 4.9 will take boost easily.
The real challenge is turbo on a carb.
You may find some info on www.hotrodders.com
I wish you luck on it.
Arn
northstar
Report this Post09-10-2013 05:32 PM Click Here to See the Profile for northstarSend a Private Message to northstarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I WOULD REALLY LIKE TO TURBO THIS 4.9 KEEP IN MIND I HAVE A CARBURATED ENGINE WITH JUST AN HEI DISTRIB, WHAT DO I NEED TO START THE PROCESS,, PARTS WISE??? THANKS EVERYONE C-NOTE
Tha Driver
Total ratings: 204
Report this Post09-10-2013 05:50 PM Click Here to See the Profile for Tha DriverClick Here to visit Tha Driver's HomePageSend a Private Message to Tha DriverEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can pressurize the carb, if you also seal it & add a way to increase the fuel pressure to compensate for boost. Or you can do a pull-through setup (no intercooler!) either mounting the carb in front of the turbo or using a priority valve. You can probably find lots of these two setups with a good search.
~ Paul
aka "Tha Driver"
Custom Fiberglass Parts
Arns85GT
Total ratings: 202
Report this Post09-10-2013 06:14 PM Click Here to See the Profile for Arns85GTSend a Private Message to Arns85GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
A carb lends itself to a super charger more than a turbo.
If you go on the Holley website you can see the options there.
The intake manifold would have to have an adapter plate, but it is do-able. You are into an area where very few have gone before if you want to turbo a carb.
Arn
darkhorizon
Total ratings: 451
Report this Post09-10-2013 06:33 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
carb in a box.....
northstar
Report this Post09-10-2013 09:58 PM Click Here to See the Profile for northstarSend a Private Message to northstarEdit/Delete MessageReply w/QuoteDirect Link to This Post
This might be a littlt over my pay grade..I'm level 5 mechanic on a 1 to 10 scale with 10 being say. Will..I would attempt it if were a bolt on application..
