  L67/F23 flywheel bolts
L67/F23 flywheel bolts by BV MotorSports
Started on: 08-27-2013 10:48 AM
Replies: 6 (402 views)
Last post by: BV MotorSports on 08-29-2013 05:07 PM
BV MotorSports
Total ratings: 189
Report this Post08-27-2013 10:48 AM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am using a cut down flywheel for my l67/F23 swap. I "think" its a '88 2.8 flywheel but I could be totally wrong. Apparently Dean used some hardware store grade8 bolts. I would like to use the correct fasteners for my application. Back in 2008 I used a spec 3800 clutch and aluminum flywheel. I went to the local GM dealer and picked up 8, f-body 3800 flywheel bolts. IIRC they ended up being 1/2 inch too short. I don't know if there is a difference in thickness between the aluminum SPEC flywheel and the OE one I have installed now.
If there is a GM flywheel bolt that works, I'd prefer to use it. However, if I can use the ARP 234-1001 SBC cam bolts, I'll go that route. Again, I'd really prefer to use a GM part(s) in this application.
BV MotorSports
Total ratings: 189
Report this Post08-27-2013 11:56 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
BUMP
NoMoreRicers
Report this Post08-28-2013 03:26 AM Click Here to See the Profile for NoMoreRicersSend a Private Message to NoMoreRicersEdit/Delete MessageReply w/QuoteDirect Link to This Post
Try looking up GM part number 24505092
I'm not sure that is right, but that's what a couple google searches led me to.
Total ratings: 463
Report this Post08-28-2013 09:55 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by BV MotorSports:
...I went to the local GM dealer and picked up 8, f-body 3800 flywheel bolts. IIRC they ended up being 1/2 inch too short.
My first thought is that they gave you flexplate bolts and not flywheel bolts.
Niterrorz
Total ratings: 132
Report this Post08-28-2013 09:16 PM Click Here to See the Profile for NiterrorzSend a Private Message to NiterrorzEdit/Delete MessageReply w/QuoteDirect Link to This Post
http://www.napaonline.com/C...DP6003149_0390113554
should be it verify first. you looking for a bolt from a front engine rear wheel manual car with a 3.8, i selected a 96 firebird.
Tstang429
Report this Post08-28-2013 11:59 PM Click Here to See the Profile for Tstang429Send a Private Message to Tstang429Edit/Delete MessageReply w/QuoteDirect Link to This Post
you want the factory gm flywheel bolts? Got a set sitting in my garage will make u one heck of a deal pm me. Brand new never installed
BV MotorSports
Total ratings: 189
Report this Post08-29-2013 05:07 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice!
