  stupid electric question
stupid electric question by todd brink
Started on: 08-22-2013 01:16 PM
Replies: 7 (397 views)
Last post by: phonedawgz on 08-23-2013 03:08 PM
todd brink
Report this Post08-22-2013 01:16 PM Click Here to See the Profile for todd brinkSend a Private Message to todd brinkEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have 84 se iron duke.....in the engine compartment ...centered towards firewall is a large white plastic electric connector ....about 30 wires connecting....what's this connection called....asking because mine is partially melted and may need to replace.
jaskispyder
Total ratings: 205
Report this Post08-22-2013 01:24 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Report this Post08-22-2013 01:51 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
84 uses different wire plan...
The alt goes thru C500 and can melt when the contacts are crap.
Fix C500 but avoid 1 red wire that goes to the alt on C500-E4. reroute that to the battery similar to later years.
also See my Cave, Alternator Sense
(Edit> I updated 1 image to show c500 pins in 84)
Ingition coil get power from C500...
Fix that and See my Cave, Fuse Links notes
[This message has been edited by theogre (edited 08-22-2013).]
CowsPatoot
Total ratings: 84
Report this Post08-23-2013 01:44 AM Click Here to See the Profile for CowsPatootClick Here to visit CowsPatoot's HomePageSend a Private Message to CowsPatootEdit/Delete MessageReply w/QuoteDirect Link to This Post
White? Hmmm...got a pic? Description sounds like it is either the C500...or the "grommet" that passes through the firewall to the ECM/C203...but the C500 should be black, and the "grommet" should be black/gray.
If you are trying to follow wiring, this might help: http://gafieroclub.org/docs...4_Wiring_Harness.jpg
CowsPatoot
Total ratings: 84
Report this Post08-23-2013 01:51 AM Click Here to See the Profile for CowsPatootClick Here to visit CowsPatoot's HomePageSend a Private Message to CowsPatootEdit/Delete MessageReply w/QuoteDirect Link to This Post
CowsPatoot
Member since May 2007
Report this Post08-23-2013 10:10 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
White? I missed that... Could be the "grommet"/bushing that passes through the firewall to the ECM etc. Not sure if 84 use 1 or 2 of them. later years use 2... 1 for ECM/C203, 1 for C500
No connections in the bulkhead "bushings" to go bad.
May look like melted is really the sealant to waterproof...
Is really melted then Check exhaust for leaks.
jaskispyder
Total ratings: 205
Report this Post08-23-2013 10:21 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
there is supposed to be a heat shield and reflective tape to protect the wires....
Total ratings: 291
Report this Post08-23-2013 03:08 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
84 has two just like the later years.
The one on the left is light gray, the one on the right is black. Same 2 piece fitting just inserted the opposite direction.
It's not an electrical connector, but just a bulkhead fitting. As long as it is still there, it is functional since all it does is separate the engine compartment from the interior. To replace it you need to disconnect the connectors in the console, pull the harness back into the engine compartment, put a loop in the cable that contains the bulkhead fitting and put in a coffee can of boiling water. I have never just inserted it in the boiling water but instead put the fitting in the water and boiled it. So just putting it in might not be enough. Anyways after it is warm enough it will come off leaving a big 'hot glue' piece on the wire. Since you are just replacing the fitting (right?) you can leave that on the wire and then fit the replacement over the hot glue thing.
The only way to get the fitting is to get one from a Fiero or one of the smaller FWD 80s cars in the junk yard. The 80s FWDs have it near the passengers footwell where the cables exit there. Not all bulkhead fittings are the same so measure before you go. And yes it is a pain getting them from the FWDs.
