  Suspention fix question
Suspention fix question by NightMare Cruiser
Started on: 08-20-2013 09:50 PM
Replies: 7 (310 views)
Last post by: NightMare Cruiser on 08-23-2013 11:24 PM
NightMare Cruiser
Report this Post08-20-2013 09:50 PM Click Here to See the Profile for NightMare CruiserSend a Private Message to NightMare CruiserEdit/Delete MessageReply w/QuoteDirect Link to This Post
After the 3800 swap I had the car aligned. Now after a few weeks and 300 miles it feels "wishy washy" car wiggles a little as you drive. Almost like it's really windy out side. Also the steering wheel used to be straight (9 & 3) now the left side is at 10 and the right at 4. For a few miles if I turned right the wheel would correct its' self. I went under car and looked around, nothing clunking or banging. What could this be?? I don't want to order something I don't need. Also want to do most work myself before hitting up the local STS shop.
Report this Post08-20-2013 09:58 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
something slipped on the alignment I think.
MadMark
Report this Post08-20-2013 10:51 PM Click Here to See the Profile for MadMarkSend a Private Message to MadMarkEdit/Delete MessageReply w/QuoteDirect Link to This Post
I agree, something slipped on the alignment. I had the same trouble with my 88 GT for a few years. I kept getting it aligned and it kept going out of alignment. I don't know if you have an 88 or not, but if you do before you get it aligned again, buy some of Rodney Dickmans paddle nuts and bolts for the upper A-Arms. These nuts are slightly compressed and will not back off.
NightMare Cruiser
Report this Post08-20-2013 10:56 PM Click Here to See the Profile for NightMare CruiserSend a Private Message to NightMare CruiserEdit/Delete MessageReply w/QuoteDirect Link to This Post
1987 base with 3800 sc swap
Fieroking
Total ratings: 78
Report this Post08-22-2013 06:38 PM Click Here to See the Profile for FierokingClick Here to visit Fieroking's HomePageSend a Private Message to FierokingEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check the torque on the axle nuts. They can make the car feel squirrely.
Joe Sokol
85 SE Daily driver with a 3.4 DOHC OBD II
88 Formula/GT 4.9 Allante Intake (My Baby)
www.fieroking.com
mitchjl22
Report this Post08-23-2013 02:32 AM Click Here to See the Profile for mitchjl22Send a Private Message to mitchjl22Edit/Delete MessageReply w/QuoteDirect Link to This Post
Joe Sokol
Hehe.... i had my wheel bearing shear in half because of the rear axle nuts.... btw they should be 200ft lbs... and make sure your wheel bearings aren't bad.
tesmith66
Total ratings: 135
Report this Post08-23-2013 08:52 AM Click Here to See the Profile for tesmith66Send a Private Message to tesmith66Edit/Delete MessageReply w/QuoteDirect Link to This Post
Loose axle nuts and / or cradle bolts will cause this. Loose or worn suspension & steering components will, too, but the alignment shop SHOULD have caught those.
NightMare Cruiser
Report this Post08-23-2013 11:24 PM Click Here to See the Profile for NightMare CruiserSend a Private Message to NightMare CruiserEdit/Delete MessageReply w/QuoteDirect Link to This Post
Today I tightened all 4 cradle bolts and both axel bolts. None of them were loose. I did notice a "little" bit of play in the rear pass wheel. Tomorrow i'll replace that bearing. I also replaced the front shocks. The driver one was fine. The Pass one was DONE!! Car drove a little bit better. Gotta replace the rear struts also. Then go directly and get the alignment done again.
