  86 SE V6 Engine Questions
86 SE V6 Engine Questions by Bahrbarian
Started on: 08-17-2013 12:23 AM
Replies: 6 (491 views)
Last post by: Bahrbarian on 08-19-2013 10:35 AM
Bahrbarian
Report this Post08-17-2013 12:23 AM Click Here to See the Profile for BahrbarianSend a Private Message to BahrbarianEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just curious if this is stock or not, I'm picking up an 86 V6 SE (for parts) and I noticed that it said "Holley" on the air intake tube but I didn't see that it had the Holley intake scoop on the side of the car. Is that normal or did someone just add the tube? Also, the red aluminum intake doesn't have the cast-in Fiero on it. I assume that wasn't on all Fiero V6's then or does that mean this engine has been replaced at one point or another? Sorry, my knowledge about stock Fieros is pretty slim as I currently only have one and I'm doing the popular 3800 swap on it. Thanks!
trotterlg
Report this Post08-17-2013 12:44 AM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
When it came out the factory door it had "Fiero" on it. Larry
Bahrbarian
Report this Post08-17-2013 12:53 AM Click Here to See the Profile for BahrbarianSend a Private Message to BahrbarianEdit/Delete MessageReply w/QuoteDirect Link to This Post
Aha, so chances are that the engine is NOT original then... I didn't try to find any serial numbers on it but I guess for $250 for the whole car, what's the big deal, right?
trotterlg
Report this Post08-17-2013 01:11 AM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
At least it will be fun taking it apart and figuring out what you really have. Larry
Bloozberry
Total ratings: 311
Report this Post08-17-2013 07:01 AM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
In '86 the plenum only had a sticker saying Fiero on it. It was either in '87 but more likely only in '88 that the word Fiero was cast into the top of the plenum.
Total ratings: 154
Report this Post08-17-2013 09:29 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Blooze is partially correct. The 85 and 86 V6 plenum had a sticker on a flat smooth surface that read "Fiero" printed in black. With age, some of those have come off the intake so it will have nothing there. In 87 and 88 Fiero was engraved into the plenum.
Holley is the company that made all throttle bodies for the Fiero V6 engines, so that is a stock part. The stock side air intake was recessed. The Holley or Fiero side scoop was an aftermarket piece.
Bahrbarian
Report this Post08-19-2013 10:35 AM Click Here to See the Profile for BahrbarianSend a Private Message to BahrbarianEdit/Delete MessageReply w/QuoteDirect Link to This Post
That would make sense. Thanks guys!
