  Suspension and Steering wheel.
Suspension and Steering wheel. by NightMare Cruiser
Started on: 08-05-2013 09:59 PM
Replies: 2 (186 views)
Last post by: donuteater306 on 08-06-2013 12:58 AM
NightMare Cruiser
Report this Post08-05-2013 09:59 PM Click Here to See the Profile for NightMare CruiserSend a Private Message to NightMare CruiserEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just noticed my Steering wheel will be straight (9am -3pm) on. If I make a hard left the steering wheel goes out of alignment (10am 4pm) make a hard right and it goes back to normal. What should I look at first?? I realize it's not the steering wheel. When I did the engine swap. the rear link felt very tight.
It's a CAR, now drive it!!
http://s1277.beta.photobuck...50016365924013387734
Coming Soon 3800 swap: Fierox: Mounts
DaytonTD
Report this Post08-05-2013 10:22 PM Click Here to See the Profile for DaytonTDSend a Private Message to DaytonTDEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had this on a Mack truck I drive, however it ended up being a U-bolt loose on the front axle. Can't really claim that for a Fiero haha.
I would wiggle your front tires and see if there is any looseness or play. Could be worn out front tie rod ends or bad wheel alignment.
EDIT: It could also be a loose upper front ball-joint where it attaches to the A-Arm
[This message has been edited by DaytonTD (edited 08-05-2013).]
donuteater306
Report this Post08-06-2013 12:58 AM Click Here to See the Profile for donuteater306Send a Private Message to donuteater306Edit/Delete MessageReply w/QuoteDirect Link to This Post
First, check the mounting of the steering rack. Make sure everything is tight.
If it is, check the pre-load on the rack. I had a similar issue with my 87 GT where as if I turned the wheel while not rolling, my rack would actually skip a tooth. Adjusting the pre-load ended that problem.
