  Any trick to popping out driver's side axle, from trans. on '88 V6 auto.
Any trick to popping out driver's side axle, from trans. on '88 V6 auto. by hdryder
Started on: 08-03-2013 07:35 PM
Replies: 3 (128 views)
Last post by: Patrick on 08-03-2013 08:53 PM
hdryder
Report this Post08-03-2013 07:35 PM Click Here to See the Profile for hdryderSend a Private Message to hdryderEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm having some trouble trying to pop out the driver's side axle from the automatic transmission. I got the passenger side out, but the driver's side does not have as much room to get a pry bar in, and so far I have not got it out.
It started to rain, so I will give it another try tomorrow.
Last year I popped out the axles on a '88 5-speed, with out much problem, when I did a clutch job.
Thanks for the help.
Arns85GT
Total ratings: 202
Report this Post08-03-2013 07:50 PM Click Here to See the Profile for Arns85GTSend a Private Message to Arns85GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
It takes a sharp blow. It is easier if you unhook the back cradle bolts and the dog bone, and drop the cradle down some to get at it from above.
Maybe somebody else will pipe in with a better answer. Good luck
Arn
weloveour86se
Total ratings: 75
Report this Post08-03-2013 08:45 PM Click Here to See the Profile for weloveour86seSend a Private Message to weloveour86seEdit/Delete MessageReply w/QuoteDirect Link to This Post
I dunno if this will work on an 88 but this is what I have heard...
Home made slide hammer type tool. Wrap a chain around the axle then wrap the other end around the head of a sledge hammer. A little slack and swing the hammer out. Should be enough to pop it. You may need a helper to catch the axle. I think I read it in Ogre's Cave. Not sure though.
Good luck!
Total ratings: 463
Report this Post08-03-2013 08:53 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Look at the suggestions in This thread.
