  starting 3800sc swap
starting 3800sc swap by Grizz54
Started on: 07-30-2013 11:34 PM
Replies: 11 (289 views)
Last post by: DPoppelll on 08-02-2013 10:37 AM
Grizz54
Report this Post07-30-2013 11:34 PM Click Here to See the Profile for Grizz54Send a Private Message to Grizz54Edit/Delete MessageReply w/QuoteDirect Link to This Post
Well, I'm getting ready to do a 3800sc engine swap into an 85 Fiero. The engine is a series I from a 95 regal. I want to use a manual transmission and would like some input as to what transmissions I can use and what my best choice would be. The car will mainly be used for cruising ( not much over 65 mph) but I might do some solo racing and possibly some road racing (nothing over 110 mph). For solo racing and road racing I will be running a 195/60R14 tire.
If you have some tried and true experience with different trans. ratios, I'd appreciate your advice.
Lou6t4gto
Report this Post07-31-2013 12:16 AM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Getrag is the best trans. WHY are you using 14" tires ? they don't do "anything" for Handling, & you are limited to what you can do for brake upgrades. Why not 16" or 17" with low profile sidewalls ? I personally don't like "Bigger" than 17" (gets "Hotwheels looking"). just curious
Grizz54
Report this Post07-31-2013 06:28 AM Click Here to See the Profile for Grizz54Send a Private Message to Grizz54Edit/Delete MessageReply w/QuoteDirect Link to This Post
I did a limited amount of solo racing a few years back (most races were 1 1/2 to 2 hrs away) and bought a set of 14" stickies for my 2.8 car. I don't intend to do a whole lot of racing with this one for the same reason, and would rather spend the money on show.
Total ratings: 290
Report this Post07-31-2013 08:34 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
FIEROFLYER
Total ratings: 180
Report this Post07-31-2013 10:11 PM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
I would say F23 all the way for the series I
DARN Cars now open with
Slow6
Report this Post08-01-2013 12:07 AM Click Here to See the Profile for Slow6Send a Private Message to Slow6Edit/Delete MessageReply w/QuoteDirect Link to This Post
Just curious. Why did you opt for a series I and not a II or III?
Grizz54
Report this Post08-01-2013 07:16 AM Click Here to See the Profile for Grizz54Send a Private Message to Grizz54Edit/Delete MessageReply w/QuoteDirect Link to This Post
I bought the wrecked Rivie, pulled everything I needed and sold the rest. I have $100.00 invested.
I have been searching build threads and am confused on what I need for a flywheel and clutch. Will any year 3800 camaro/firebird flywheel work? Best clutch?
FIEROFLYER
Total ratings: 180
Report this Post08-01-2013 09:46 AM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
96 to last year of that model F body 3800 manual flywheel machined down to .840 or .820 as some like and balanced to match the auto flex plate your series I came with. Dan
1fast2m4
Report this Post08-01-2013 11:24 PM Click Here to See the Profile for 1fast2m4Send a Private Message to 1fast2m4Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have done some research and SPEC makes a clutch for this application I believe you can use there Aluminum flywheel ($$$$$) or Like FieroFlyer said use a 96+ 3800 F-Body flywheel turned down to .8xx" but what I'm not 100% clear on is can you use a 96+ F-Body Pressure plate along with a Clutch disk for the trans you choose to use? If your on a Pick-n-Pull budget that may work, but like I say, I'm not sure.
1986 SE 3800SC/4t65eHD (12.871@104.96) I'll Sell it if you like
1985 GT 3800SC (swap in progress)
Grizz54
Report this Post08-01-2013 11:41 PM Click Here to See the Profile for Grizz54Send a Private Message to Grizz54Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks to all for the input. I did check into the alum. flywheel. Nice but not really necessary for the main purpose I have for the car. And I'd rather spend the money on other mods. I'll have to check the threads again on the Spec clutches. Seems I read that the Spec 3 didn't hold. Don't know the difference between a 3 and 4.
revin
Total ratings: 234
Report this Post08-02-2013 09:44 AM Click Here to See the Profile for revinSend a Private Message to revinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Spec 3 OR Spec 3+ willl hold for the power you put down. Series1 not as powerful as the Series II hp wise.
If the 3 is not holding, there are more mods done than it can handle and should beupgraded to a 3+ or better then.
DPoppelll
Report this Post08-02-2013 10:37 AM Click Here to See the Profile for DPoppelllSend a Private Message to DPoppelllEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a similar swap in the works. whats the big difference between the F23 and the F40 in terms of performance and the ease with which they can be swapped in?
DanP
