  Cavalier digital dash, outside temp ???
Cavalier digital dash, outside temp ??? by S-toon
Started on: 07-29-2013 07:04 PM
Replies: 3 (322 views)
Last post by: S-toon on 07-30-2013 12:39 PM
S-toon
Report this Post07-29-2013 07:04 PM Click Here to See the Profile for S-toonSend a Private Message to S-toonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok so I have the cavalier digital dash installed. Don't know anything about electrical, just followed instructions and everything worked. Had it installed for about a year now with no problems. So my question is, would it be possible to display the engine/coolant temp whatever you wanna call it, on the outside temp display. So basically unplug the wires going to the outside temp sensor and splice into the wires going to the temp gauge, would it also show the temp on the "outside temp" display? Or is it more complicated then that? If yeah what would it take to make it work?
Here is a pic I found for reference.
cmechmann
Report this Post07-29-2013 08:53 PM Click Here to See the Profile for cmechmannSend a Private Message to cmechmannEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think the wiring part would work.
However I don't think that the display can display high enough.
At the least, I think the most it would display is 199.
PaulJK
Total ratings: 237
Report this Post07-30-2013 02:23 AM Click Here to See the Profile for PaulJKSend a Private Message to PaulJKEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by S-toon:
... unplug the wires going to the outside temp sensor and splice into the wires going to the temp gauge ...
i would not do this. the gauge in the display is designed to read the signal from the outside temp probe. if you want a temp. reading from the cooling system, re-mount the outside temp. probe onto the radiator.
S-toon
Report this Post07-30-2013 12:39 PM Click Here to See the Profile for S-toonSend a Private Message to S-toonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, I was thinking that it might work since both gauges are for temp, but that makes sense.
