  1987 V6, automatic, cable end on transaxle. Plastic end coming off.
1987 V6, automatic, cable end on transaxle. Plastic end coming off. by 1987Fiero_GT
Started on: 07-28-2013 05:46 PM
Replies: 3 (108 views)
Last post by: EvilSqueezles on 07-29-2013 05:21 PM
1987Fiero_GT
Report this Post07-28-2013 05:46 PM Click Here to See the Profile for 1987Fiero_GTSend a Private Message to 1987Fiero_GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey guys,
I have a 1987 Fiero GT fastback with a V6 and automatic transmission. The transaxle end of my cable has a plastic piece which pops down over the little ball post for gear changing. This plastic piece will not remain on the ball post. I acquired the car with the issue so I am not familiar with what proper attachment should look like.
A little info gained by visual observation...
There is no clip on top nor any insert inside the plastic end. Right now it just sits on top of the post until it slips up and off. The previous owner used a tie wrap to help maintain the angle of the cable which helps a lot! But I need to remedy this issue with a more permanent fix.
Any and all input would be most appreciated!!!
Jeff
jb1
Report this Post07-28-2013 11:45 PM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
new cable would be my best guess..
87 GT
(series II swap in progress)
85GT Northstar
86GT 3800 n/a
Tweeder
Report this Post07-29-2013 12:55 AM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
Duck tape,lol. What about taking the arm off, flip it over and grind it down till you can see the stem of the ball and punch it out. You will be left with a hole, put a bolt with a nylock nut and I think that'll work?
EvilSqueezles
Report this Post07-29-2013 05:21 PM Click Here to See the Profile for EvilSqueezlesSend a Private Message to EvilSqueezlesEdit/Delete MessageReply w/QuoteDirect Link to This Post
